Sponsored by: DashLynx
Is It Just Me Or Is 1st Gear Useless?
Old 11-14-2012, 09:14 AM
Evoking's Avatar
Default Is It Just Me Or Is 1st Gear Useless?
I used to go down to first if I want to feel the rush of the beast. But I've come to the conclusion that the car might be faster launching from 2nd! In fact, I launched from 2nd yesterday and it still lit the tires - but it held the same gear past 60 as we eliminate the shift too.
So much effort to feather 1st gear we might as well bypass it all together! Certainly not a complaint - just a testament to what a stonking motor this is
Old 11-14-2012, 11:14 AM
carzaddict's Avatar
its not that its useless, its just that Jaguar doesnt use it in its normal use.
ive noticed this as well and tried to come up with my own answers
- in terms of comfort...starting in second is better, less "launchy" for the everyday driver
- better for effeciency.
a lot of other companies do that as well. I wonder if the car is in Sport mode and you launch it, if it will kick down into first
Old 11-14-2012, 11:46 AM
Evoking's Avatar
I know it doesn't automatically start in 1st. Nor should it. But even if I'm in full manual and want best launch. I'm saying I don't think 1st would make the car any faster.
Old 11-14-2012, 12:00 PM
mosesbotbol's Avatar
Received 1,198 Likes on 931 Posts
Must be a ZF thing rather than Jaguar.
Old 11-14-2012, 12:28 PM
Octurbo's Avatar
I agree. I never use first gear. My car really struggles for traction in 2nd gear, so 1st gear is a waste of time (in addition, rpm's climb quickly). It seems to me, that when you put the car in sport auto, it starts out in 2nd as well, so I'm not sure why there is a first.
I mentioned in an old post that I wished they would have made 2nd gear into 1st gear, so they could have shortened the ratios of the gears or added a tall 6th gear (1-1.5k rpm's at 75mph) to improve fuel economy.
Old 11-14-2012, 02:41 PM
muncher's Avatar
I launched from 1st with the traction control fully off recently......just to see what it could do. I planted my right foot and boom i was in the red zone in a fraction of a sec. The car changed the gear for me before i did. I always launch in 2nd. Reckon that would be the quickest/best way to launch. I am trying to get some time away from work to do some 1/4 mile tests. Try to find out the best combo for optimum launch.
Old 11-14-2012, 03:44 PM
can't wait to hear launch results. haven't launched the car yet. any other tips for doing so? was never an automatic trans guy until the jag's.
Old 11-14-2012, 11:20 PM
Xk in DXB's Avatar
...maybe i need to read the manual ...however when you guys refer to 'launch' are you talking about a specific launch control mode like on the Nissan GTR? ...or are you just talking about stopmin' on it from a stand still?
As for 1st gear ...agreed, pretty useless. 2nd gear has a longer pull and gets you going better then 1st does.
Old 11-15-2012, 02:15 AM
dutch07xk's Avatar
The first gear in cars is officially designed as a gear to move the car easier from standing still. There's less torque on the transmission and clutch plates because of the higher ratio (an auto transmission also has clutch plates) The result is less wear on the driveline.
So even when you feel there's no use in the acceleration aspect, you might want to do yourself a favour by putting less strain on your transmission. It will live longer.
Old 04-21-2013, 03:10 AM
Xk in DXB's Avatar
Treu Dutchy
If I'm just cruisin' I wont bother with 1st, but have 'adjusted' my driving style and now use 1st more frequently.
Makes a nice noise in 1st when the traction control is off and you stomp on it!!! ;-)
Old 04-21-2013, 04:44 AM
jagxk2008's Avatar
so you meant it is good in sport mode using first gear to start?
Old 04-21-2013, 09:24 AM
amcdonal86's Avatar
I don't know about you guys, but my XKR starts from first in D and S modes (automatic). Count the shifts as you accelerate to highway speed!
Old 04-25-2013, 09:24 AM
jagxk2008's Avatar
But in sport manual then? if you use the paddles arrive at a stop, you will re-start in second automatically,( I meant if you forget to downshift manually) specially due to the gear box downshifting for you in manual mode anyway. it's what mine does. I often use the paddle but quickly I beleive i am in automatic mode and forget to downshift, the car does it for me, very well, Thank you! but then it start again from second gear, and if i need to start in first i do need to downshift one more gear manually, what the car won't do for me when it does downshift for me, when you forgot to do it.
Its probably better downshifting manually to first gear once you are stopped as while driving it really sounds awkward, no?
Old 04-25-2013, 09:43 AM
amcdonal86's Avatar
It will put it in second, because that's the highest gear that it can start from. I will have to doublecheck, but if left to its own devices in full automatic mode (D), I'm pretty sure the car starts in first gear. This is different than it was in my X350.
Old 04-25-2013, 09:45 AM
jagxk2008's Avatar
you counted 5 shifts then?
Old 04-25-2013, 09:54 AM
amcdonal86's Avatar
Exactly. I will doublecheck--I did this test months ago when it came up in another thread. Someone else said the same thing (that it always starts in first gear) and I didn't believe them. So I tried it out myself, and sure enough, the car starts in first gear!
jagxk2008 (04-25-2013)
Old 04-25-2013, 10:00 AM
jagxk2008's Avatar
so it is only related to manual mode if you do not downshift to first manually, the car will start (or stay) in second gear, since in sport mode you may not manually downshift to first as its sounds weird (while slowing down/ stopping), you do not do it while you are stopped then you have tendancy to only use second to launch. So we are actually "saving" our transmission in D mode.
Old 04-25-2013, 10:02 AM
amcdonal86's Avatar
I believe this to be the case, yes. It shifts into 2nd as you come to a stop in manual mode (if you don't downshift into 1st) as this is probably the highest gear it is allowed to start in and is closest to the gear you left it in.
Old 04-25-2013, 10:09 AM
jagxk2008's Avatar
thanks it seems its clear now, good we talked about it. I don't want mess the transmission, as I feel using the paddles sport mode, dynamic etc, puts a lot on the transmission, maybe i am wrong
Old 04-25-2013, 02:12 PM
Executive's Avatar
Porsche's PDK does the same.
That's been my experience as well, but with traction control engaged.
I personally like the first gear launches as it just nudges you back into the seat.
Quick Reply: Is It Just Me Or Is 1st Gear Useless?
