Key fob
Old Jul 5, 2015 | 06:55 AM
Gmancuso's Avatar
Default Key fob
Received low smart key battery message and replaced the battery. Have done this before with no problems. New battery installed and fob doesn't work at all. Any ideas as to why. Thanks in advance.
Old Jul 5, 2015 | 08:48 AM
kj07xk's Avatar
1. New battery might be a dud.
2. Battery not making contact in the case.
3. Battery upside down.
Try putting the old battery back in, and see if you get the warning back.
If yes, then I'd suspect 1 above.
If not, then 2 or 3.
Old Jul 5, 2015 | 11:09 AM
Stuart S's Avatar
I bought cheap Chinese-made watch batteries on Amazon in the past that didn't last long or turned out to be duds. Since then, I've bought only brand name watch batteries with expiration dates with at least 2 years left at my local drug store and haven't had any problems. Well worth the extra cost.
Old Jul 5, 2015 | 11:53 AM
guy's Avatar
guy
There is a known issue with the prongs.
Carefully slightly bend up the prongs and clean then with contact cleaner.
Old Jul 6, 2015 | 04:50 AM
Gmancuso's Avatar
Thanks guys. Tried all of the above, none seem to work. A real pain having to use the key to gain access. What are your opinions on a weak car battery?
Old Jul 6, 2015 | 07:11 AM
mjsammon's Avatar
If you still have the old battery pop it in and see if you get the low smart key battery message. This will verify if the electronics in the fob are still functioning.
philwarner
28
Jul 11, 2017 10:21 AM
redxk8
Sep 30, 2015 08:18 AM
Listers
Sep 30, 2015 07:45 AM
Jzar
Sep 27, 2015 02:55 PM
