Knock in front wheel
Old Mar 4, 2025 | 08:19 PM
One&Done's Avatar
Default Knock in front wheel
Thought I would post before I bring her to the mechanic. When I drive over small / sharp bumps, I hear a knock or little bang coming from the right front wheel. Any idea what it could be? I want to be prepared and informed. A visual check shows nothing loose or out of the ordinary. Hoping for an inexpensive fix.
Old Mar 4, 2025 | 09:07 PM
sony2000's Avatar
Lower ball joint, or top or bottom of the strut shock, and lastly the stabilizer link.
Old Mar 5, 2025 | 03:50 AM
RichardS's Avatar
Most likely to be the track rod ball joint (tie bar in the USA, I believe) but, as above, could be any of the steering or suspension pivot points.
Richard
Old Mar 5, 2025 | 08:20 AM
neilr's Avatar
Stabilizer links are fairly feeble, and cheap to buy and replace. If nothing appears to be loose, I would try them first, even if they don't appear to have play.
Old Mar 5, 2025 | 08:25 AM
wymjym's Avatar
and my guess is...most likely the stabilizer (sway) bar bushing.
wj
Old Mar 5, 2025 | 09:06 AM
kj07xk's Avatar
Take the wheel off and do a visual inspection. I was getting a knock over bumps, and I found the shock was leaking (telltale streaks down the lower part of the shock). Replaced, and the knocks were solved.
Garpusmentus
Sep 18, 2022 09:22 AM
jagrodrigues
May 27, 2021 05:21 AM
Truebrit
XK120 XK140 XK150
Mar 28, 2019 06:47 AM
nebelfuerst
Jun 14, 2015 03:49 PM
