Leather seat (driver side)
Old Apr 20, 2021 | 07:51 PM
Ter11's Avatar
Default Leather seat (driver side)
Hi all
After only 28k miles the left leather bolster of the driver seat is starting to show wear. What do you recommend??
I have never seen such wear so early on any car before! A bit shocked...
br
ter
Old Apr 20, 2021 | 08:00 PM
Cee Jay's Avatar
That's a pretty specific spot to go bad so quickly. Do you wear a certain type of trousers that may have rivets or some such in a particular area?
Old Apr 20, 2021 | 08:27 PM
Stuart S's Avatar
See my Post #14 in this thread:
https://www.jaguarforums.com/forum/x...r-seat-217609/
I'm not sure if Dynamix, a UK company, is still in business. If not, then search the internet for other companies that make factory-matched, water based auto leather dye that you apply with a small sponge, not a spray can.
Old Apr 21, 2021 | 02:40 AM
You will find several threads on this topic across many of our Model forums. It's especially an issue with X308's. See my post #4 in this thread for a "before and after" example:
https://www.jaguarforums.com/forum/x...er-dye-213971/
I replied to a question about dye suppliers elsewhere on the forums recently and found my local supplier now has an outlet in the US:
https://www.furnitureclinic.com/color-chart/jaguar
I've used Furniture Clinic products several times and always had good results. If you trawl through other threads on the topic, you will find Leatherique and Gliptone equivalents are also recommended.
Old Apr 26, 2021 | 09:21 AM
Jaunty's Avatar
That's not wear, that's damage, caused by some object coming into contact with the leather, just once by the look of it. A commonly-worn belt buckle, for instance would leave a succession of little marks almost on top of each other.
I use a Scratch Doctor leather touch up pen, matched to the Jaguar trim code from the door pillar plate. Excellent.
darbysan
May 21, 2019 07:16 PM
Ter11
May 20, 2019 11:48 PM
Carnival Kid
Jan 17, 2019 07:51 PM
MHT
Dec 3, 2015 01:09 PM
Frog
Feb 10, 2011 02:13 AM
