LH/RH lower wishbone arms
Old Jul 15, 2017 | 05:39 PM
jahummer's Avatar
Originally Posted by Cambo
I will never put polybushes in a street car ever again, the creaking/squeaking is unbearable, pretty much ruins the car.
What car did you convert to poly? I intend to do a complete Powerflex conversion next month as my 5 year old warranty replacement control arm bushes are about done after 4K miles. I understand if you grease them correctly, they will NOT squeak.
Old Jul 15, 2017 | 05:49 PM
Cambo's Avatar
The XJR, put poly in place of some standard rubber bushes, I left all the spherical joint bushes as stock;
Front upper wishbone bushes
And the front bushes of both the upper and lower rear wishbones
Also did the rear sway bar bushes.
I totally wish I hadn't and they will all be ripped out and replaced with standard rubber OEM bushes when I get a chance to put the car off the road for an extended period.
Old Jul 15, 2017 | 06:12 PM
jahummer's Avatar
Perhaps a bit unbecoming for a saloon but more appropriate for a sport coupe? I miss the SuperV8 and I found the suspension on that car to be flawless, minus the same rotten bushes that I had to replace, under warranty.
Old Jul 15, 2017 | 09:41 PM
Cambo's Avatar
Are sport coupe's meant to creak and groan as you ease your way over speed humps?
Not a chance in hell I'll put poly bushes in my XKR.
Old Jul 17, 2017 | 10:43 AM
Rey's Avatar
Rey
I replaced sway bar bushings on another car with poly bushings. I added grease fittings to the exterior metal bushing holder plus a very small hole in the bushings for grease to reach the bearing surface. No noise. Wonder if anyone has tried this on a Jag's poly bushings.
Old Jul 20, 2017 | 07:20 AM
8bit's Avatar
As I have a set of XKR-S springs & shocks here, I intend to take some ride height and camber measurements with the stock XKR springs, and later on with the XKR-S ones, and if it comes out too negative, then it'll have to be a pair of XKR-S wishbones as well...
Mind keeping us posted on this please? I may be interested.
