Little beeping sound while accelarating when hot
Old Aug 6, 2020 | 11:57 AM
earny's Avatar
Default Little beeping sound while accelarating when hot
Now in the hot summer my XK 5.0 NA has a low beeping sound when accelerating the warm engine. After about 2 minutes of driving it gets better. The noise can be controlled with the accelerator - the more the louder. At first I thought about the air conditioning or the ventilation, but it seems to be power or pressure dependent and comes from the front or engine compartment.
Any ideas where to look?
Thx in advance,
bernd
Old Aug 6, 2020 | 02:59 PM
trkyam's Avatar
electronic beeping? or are we talking a whistle?
Old Aug 6, 2020 | 03:24 PM
earny's Avatar
Thx - No, nothing electronically. A whistle, not loud, but getting a little bit louder when accelatring. Like a hose loosing some pressure through a minor hole. I will tomorrow try to make a video.
Old Aug 6, 2020 | 04:04 PM
MarkyUK's Avatar
Well you didn't explain that well from your first post, a beep is defo something completely different.
Old Aug 6, 2020 | 05:11 PM
jahummer's Avatar
Does it go away if you turn the AC off?
Old Aug 7, 2020 | 06:00 AM
earny's Avatar
I will try different options today. Maybe I can somehow limit the possibilities. And sorry for my unprecise explanation, that is sometimes a little bit difficult with school knowledge of your language more than 40 years ago.;-)
Old Aug 7, 2020 | 06:30 AM
Sovejag13190's Avatar
Hi it's possible that is a belt problem or belt tensioner.
Old Aug 8, 2020 | 08:18 AM
earny's Avatar
I almost don't dare to do an update: it was because of the air conditioning that caused the whistle when running at high speed. If you close the air vents a bit more, the little noise disappears.
Thx all,
bernd
Old Aug 8, 2020 | 08:41 AM
jahummer's Avatar
Thank you for the update.
That’s why I asked about the AC...could be a Freon level issue or perhaps your vin is affected by the TSB regarding adding a spacer to the AC line.
Old Aug 8, 2020 | 12:10 PM
earny's Avatar
Thanks again for the TSB info.
bernd
camstang6907
Apr 12, 2020 10:42 PM
Dell Gailey
Aug 23, 2018 03:07 PM
Michaell
Feb 17, 2015 10:43 AM
Oddman
XJ40 ( XJ81 )
Sep 4, 2012 06:06 AM
user 2029223
Feb 17, 2011 04:50 PM
