Make to XK Handle Like a Lotus?
My 2011 XKR has no noticable bump-steer (German roads). If the suspension is good and correctly aligned, it should be OK on this front. The 5.0 cars are stiffer sprung than the 4.2 cars but again on the move, they are a nice balance between comfort and sharp handling. Around town, something more sedate usually works better though.
Mine came on Dunlops. They were perfectly fine on grip and safety but strangely dull. Eventually switched them out to the Continental SportContact 7 and they transformed the car. Much more fluid and "lively" and probably more absolute grip but even the ancient Dunlops didn't ever let go when they shouldn't have. Tyres have come such a long way in those last 15 years, finding a good set that suits you is highly recommended. The only down side of the Contis is that they are slightly noisier than the Dunlops, and the XK (my coupe at least) seems to let in more sound from around the back than expected.
Yes, find a good one and try it out.The X150 can still be a nice car to drive 15 years after its first release.
The R-S GT rack is quite different, different ratio and different assist valving. I fitted one to mine and the difference was substantial, heavier, more precise better handling. Then of course I've got customer sway bars, multiway adjustable digressive coilovers and custom suspension links and Powerflex poly bushes.
Those running all seasons will never see the handling gains of an ultra sport summer tire. And that width of that solid band of rubber on the tire tread has a significant effect on steering compared to those tires that don't. Load ratings have an effect as the sidewalls are stiffer.
Couple with that tire age, Not to be overlooked. I find after 3 years its time to change them up.
And I've been known to reduce tire pressures by up to 10%, depending on venue, temperatures, humidity.
Of course, if you've messed with the geometry with spacers... I think you're wasting your time.
Do you have 20s and 19s? The handling differences there are interesting as well.
Interesting that some of my friends with much more HP of course have me on the straights. The moment we get to winding roads, I'm right there. And those roads with sharp corners, I'm gaining ground and passing... its all in the tire.
My 2011 XKR has no noticable bump-steer (German roads). If the suspension is good and correctly aligned, it should be OK on this front.The 5.0 cars are stiffer sprung than the 4.2 cars but again on the move, they are a nice balance between comfort and sharp handling. Around town, something more sedate usually works better though.
Depending on your budget and how far you want to take it, I'd take a good look at what Jag did to the XKR-S GT. Which was basically to bolt on F-Type suspension components and the F-Type rack. You'll get a wider track and also slightly lighter components (I believe?). Your steering ratio will be quicker for a better turn in. This is all bolt in (not sure if you need to calibrate rack). If you can find a wrecked F-Type that could be a worthwhile project.
What does that mean for a non XKR-S? probably get better brakes and look at swapping over suspension parts from the R-S, Be prepared to be shocked at the price of a steering rack however.
Sean W
Mar 2, 2022 02:12 PM
