MAP Pressure sensor
Old Dec 4, 2022 | 04:11 PM
marcoshilario's Avatar
Default MAP Pressure sensor
Hello.
I have a recurrently failure (check engine light) that is generated by the TMAP or Pressure sensor, that senses the incoming air pressure to the engine.
I bought a new sensor and before installing it, I would like to check if someone has done it before, without the help of a Jaguar service.
The item I bought says it should be installed by trained staff.
Is there something I should consider before installing it?
Thank you.
Old Dec 5, 2022 | 06:44 PM
trkyam's Avatar
That is a very easy install,
Please note, I highly doubt your MAP sensor failed (rare), it is more likely that
you have a leak in your air intake system which is causing your MAP sensor to display
a error code.
rod_f
Aug 15, 2022 10:21 AM
Jason.
Sep 12, 2021 11:59 PM
Tamas Farkas
Mar 19, 2021 12:46 PM
Blucky1969
Apr 13, 2019 09:40 PM
Magnus62
May 24, 2017 07:34 AM
