Mesh grills for brake cooling
Old Sep 10, 2018 | 05:20 PM
MarkyUK's Avatar
Default Mesh grills for brake cooling
2012 car which has these in bright chrome.
Since I'm having the diffuser and mirrors (currently chromed) wrapped in a carbon finish and the two centre grills (currently chrome) changed to black Jag ones, I thought I'd check if Jaguar has any black side grills.
I've seen them in black on performance XK's but never on a N/A
Part no's from Jaguar are
Left C2P20279
Right C2P23435
Dealer couldn't tell me if they were a chromed finish or black...I suspect chromed and that the performance ones are merely sprayed or dipped?
Any help would be appreciated.
Old Sep 10, 2018 | 08:33 PM
shemp's Avatar
The mesh or the outer trim? On my NA, the mesh is black but the trim is chrome
Old Sep 10, 2018 | 09:35 PM
jagtoes's Avatar
Left C2P20279
Right C2P23435
Those grills are not for brake cooling but for the air induction system.
Old Sep 11, 2018 | 09:50 AM
MarkyUK's Avatar
I wasn't aware that the standard N/A XK had two air filters...just shows my ignorance!
A picture paints a thousand...
So it's the outer ones level with the number plate
Old Sep 11, 2018 | 11:45 AM
jagtoes's Avatar
Yep the 2 lower outer crome trim grills are not for brake cooling. They contain the air input for the induction system. The XK is different from the XKR buy they both have 2 matched air filters located up behind the grills. You need to remove or pull back the inner fender liner to change the filters. As far as I know there is no ducting for brake cooling. Others can chime in here with more details.
Old Sep 11, 2018 | 12:25 PM
Cee Jay's Avatar
My entire life I've always thought that the XKs had a single air inlet and XKRs had the two.... Is that year-dependent?
Old Sep 11, 2018 | 12:31 PM
shemp's Avatar
The 5.0L models have 2. The 4.2L have 1.
Old Sep 11, 2018 | 12:52 PM
kj07xk's Avatar
Damn. Good to know. If I were to move to a 5.0 XK, it would have ended up with one really clogged right-hand filter, as I would have only been changing the left one, just like my 4.2 XK.
Old Sep 11, 2018 | 01:07 PM
MarkyUK's Avatar
Still no answer as how to get black ones, if I change those two main centre grills to black it will look....well....odd!
Looks like I'll have to get them dipped?
Old Sep 11, 2018 | 01:21 PM
shemp's Avatar
Dipped, Plasti Dip them... I'd have them painted to match your car's color. You can probably buy touch up paint in a spray can using your color code (I know we can here in the states) and do them yourself, or take then to an auto body shop. Probably cost very little.
Old Sep 11, 2018 | 01:31 PM
TexasTraveler's Avatar
That's what I did...
Old Sep 11, 2018 | 02:55 PM
S-Typer's Avatar
I’m going to use the Autoflex system this week. It’s a sprayable coating similar to plasti dip.. but very glossy and a little more durable. The application is a little more time consuming but it should mimic the black pack setup.
I’ll take pics when it’s done. Also doing the chrome around the windows too.
Joe
Old Sep 11, 2018 | 03:57 PM
jagtoes's Avatar
My XKR has factory black grills . Pic below.
Old Sep 11, 2018 | 05:43 PM
MarkyUK's Avatar
It's the glaring piece of chrome that I find doesn't go, am sure there's a part number as the 'black pack' had them as per this car for sale.
https://www.autotrader.co.uk/classif...om=2012&page=5
Perhaps though the one's on the Dynamic R are different?
Old Sep 11, 2018 | 07:50 PM
u102768's Avatar
LH - C2P21132 - black surround with black mesh grille
RH - C2P21131 - black surround with black mesh grille
Old Sep 11, 2018 | 09:33 PM
jahummer's Avatar
Wait, the 5 litre XKR has the intakes that low? On the 4.2, the intakes are located in the upper front grille pointed at the bonnet.
Old Sep 12, 2018 | 12:39 AM
u102768's Avatar
The 5 litre cars are the same otherwise you would run the risk of sucking water in when driving through standing water.
Old Sep 12, 2018 | 01:53 AM
MarkyUK's Avatar
Yes at last the Antipodes comes to the rescue...we shall call it a mini Anzac Day!
Many thanks!
Old Sep 12, 2018 | 04:17 AM
MarkyUK's Avatar
Many thanks!
Ok have checked this out with jaguar dealer
chrome ones £65.08 inc VAT for both sides
black ones £236.68 inc VAT for both sides
WTF!! From what I know of chroming plastic it's quite an intensive process. Doubtless if you were to scrape the chrome off it would probably be black or white underneath.
Black however will probably be black all the way through...so how can they justify over 3 times the price!
So will be buying a set of the chrome ones and spraying them up.
So next question is how easy are they to remove?
Old Sep 12, 2018 | 07:45 AM
jagtoes's Avatar
Like anything else the cost must be related to the rarity of these parts. I would assume that not to many were made and no more are being built. So you are looking at finding new old stock.
