Mesh grills for brake cooling
Old Sep 12, 2018 | 10:07 AM
MarkyUK's Avatar
I'd say that were true but for the fact main dealer said there were 200 in stock with jaguar.
Old Sep 12, 2018 | 10:25 AM
TexasTraveler's Avatar
Originally Posted by MarkyUK
Ok have checked this out with jaguar dealer
chrome ones £65.08 inc VAT for both sides
black ones £236.68 inc VAT for both sides
WTF!! From what I know of chroming plastic it's quite an intensive process. Doubtless if you were to scrape the chrome off it would probably be black or white underneath.
Black however will probably be black all the way through...so how can they justify over 3 times the price!
So will be buying a set of the chrome ones and spraying them up.
So next question is how easy are they to remove?
On my10 removal was fairly simply, I got one side to just pop off by pulling on it.. The other side I had to loosen a few bolts in the wheel liner and reach my hand in and help push tabs from the inside. I probably could have pulled it from front, but didn't want to take the chance in breaking any tabs...
Old Sep 12, 2018 | 10:57 AM
8bit's Avatar
Originally Posted by u102768
LH - C2P21132 - black surround with black mesh grille
RH - C2P21131 - black surround with black mesh grille
Are these for the later, facelift cars with the slimmer lights as in the photo on page 1? I'm trying to find the same thing for the earlier 5.0 cars, pretty sure they're different parts but the only P/Ns I can find are the same as you listed there...
Old Sep 12, 2018 | 11:41 AM
Originally Posted by 8bit
are these for the later, facelift cars with the slimmer lights as in the photo on page 1? I'm trying to find the same thing for the earlier 5.0 cars, pretty sure they're different parts but the only p/ns i can find are the same as you listed there...
c2p21085
c2p21086
Old Sep 12, 2018 | 03:26 PM
Ranchero50's Avatar
Originally Posted by jagtoes
As far as I know there is no ducting for brake cooling. Others can chime in here with more details.
On my '07 there is a NACA duct molded into the bottom of the belly pan for the nose that sucks road air up into it and around a corner that aims it as the rotor. It's inboard of the tire walls. There's also a little air scoop for the alternator. Pretty clever in all honesty.
Old Sep 12, 2018 | 03:41 PM
jagtoes's Avatar
I just went out to the garage and looked at my 2012 (it's on the lift for the night). It has a small NACA opening under the passenger side of the plastic belly pan. It looks like it may duct to the alternator on the lower right side of the engine. In the front under the lip there are a few rows of square cutouts both in front and behind the radiator. There is no ducting to either brake rotor as both the suspension and PS rack boots and the whole wheel/brake package are in the open. That's all I got and I wonder what the S or GT package has.
Old Sep 12, 2018 | 06:14 PM
kj07xk's Avatar
In some thread, not too long ago, I believe Cambo added ducting from an S or GT to his R.
Old Sep 12, 2018 | 06:38 PM
  #28
jahummer's Avatar
There are optional F-type clip on flow directors that fit on the lower arms, they extend from the naca ducts on the under tray and curve into the center of the front rotors.
Old Sep 12, 2018 | 06:50 PM
Cee Jay's Avatar
OR:
X100 braking
Yes, it's an X100
Old Sep 12, 2018 | 07:19 PM
  #30
u102768's Avatar
They claim to be for the early 5 litre cars.
Originally Posted by TexasTraveler
c2p21085
c2p21086
Those have a chrome surround:
rclangelan
Jan 12, 2018 12:21 PM
Mpresion
Aug 15, 2012 10:09 PM
ShaguarNYC
Nov 20, 2007 01:48 PM
JagMan
Aug 17, 2007 11:07 PM
