Metallic Noise Supercharger @3000 rpm
Old Jan 23, 2023 | 10:11 AM
tcsamir21's Avatar
Default Metallic Noise Supercharger @3000 rpm
Hi! I recently replaced the „Torsion Isolator“ on my 2010 XKR
Now at around 3000 rpm if you press the throttle (around 70%+) you hear a metallic „screech“
It has to be the Supercharger because the noise wasnt there before i got the Isolator changed & if i press the throttle only about 15-20% and get over 3000rpm there is no noise but i don‘t know what it can be. Do i have to replace the snout? The old Isolator did a little bit of damage inside but it wasnt much to be honest.. car still runs perfectly fine & no problems except this noise
Here is the Video :
https://youtu.be/Yzu5vPpm8Yk
Old Jan 23, 2023 | 12:17 PM
McJag222's Avatar
I really couldn't hear the "screech".
Old Jan 23, 2023 | 12:25 PM
wymjym's Avatar
nor did I
are you sure it isn't the drive belt slipping?
wj
Old Jan 23, 2023 | 01:03 PM
tcsamir21's Avatar
the dashcam is not that good unfortunately. I tried to record it with my phone but i couldnt hear it either. This was the only Video where i could hear it. Its directly after i let off the throttle.(but even with 100% volume still quiet) i thought it was the sc whine but it cant be. Slipping belt idk but its more like an Metallic noise
You can hear the noise in the video when i passed the first white cone on the right side
Old Jan 23, 2023 | 02:48 PM
wymjym's Avatar
sorry, maybe the compression (U tube) has removed the high frequency sounds but I do not hear it
wj
944xjs
Apr 25, 2021 10:22 AM
VeeDub
Aug 28, 2019 12:59 AM
Gordo1968
Jun 16, 2018 09:43 AM
shotime92
Jul 30, 2013 10:10 PM
sverroc
Jun 20, 2012 07:12 AM
