Missfire problem cylinder 7
Old Mar 2, 2025 | 10:57 AM
ChiefyO's Avatar
Default Missfire problem cylinder 7
2007 4.2 XKR I have an issue with cylinder 7 registering a missfire , sometimes enough to trigger a eml light other times not . So far it has had full set of coil packs and plugs. 4 injectors replaced on R/H bank, R/H injector wiring loom replaced, and lastly engine ecu swapped and still it persists. Coil packs swapped and fault does not move. Reading live data missfire only registers at idle increase to around 1200 rpm and stops showing . Also usually once this is done it will sit at idle without registering any further missfires. Any help much appreciated
Old Mar 2, 2025 | 01:34 PM
Cee Jay's Avatar
Have you done a compression test? You may have a goofy valve.
Old Mar 3, 2025 | 01:50 AM
ChiefyO's Avatar
Compressions checked and all ok
Old Mar 3, 2025 | 01:18 PM
sony2000's Avatar
Clean and check electrical connections and wiring for #7.
Old Mar 3, 2025 | 01:22 PM
Cee Jay's Avatar
I'd also say to check ohms between each injector connection to ground and then to each other, compare them to other connectors. All should be very similar.
Old Mar 4, 2025 | 01:55 AM
ChiefyO's Avatar
I have changed the r/h injector loom and checked the earth point at front of head. But that is still a good suggestion
memento84
Apr 4, 2024 02:29 PM
Beretta9
Feb 3, 2024 08:20 AM
ForwardJag
22
Feb 16, 2022 04:52 PM
Sgmmiller
Apr 22, 2021 07:33 PM
Gaviatrix
Oct 27, 2010 04:37 PM
