Navigation Disc(s) Question interchange
Old Feb 2, 2017 | 03:49 PM
Sean W's Avatar
Default Navigation Disc(s) Question interchange
I'm betting this has been touched on previously but I can't find it.
1) The XJ has a single Nav disc, 2012. The XK has 2. Would the XJ disc work in the XK?
2) This is just an academic question as I don't use the Nav system anyway but curious as to why Jaguar has a 2 disc system for the XK and possibly other models but a single disc suffices in the XJ.
I half expect to see at some point in the XJ version "Beyond here, there be Dragons"
I assume they're not interchangeable, but missing the aha or "duh" moment.
Old Feb 2, 2017 | 04:07 PM
shemp's Avatar
I haven't researched it much but I thought the 2 XK DVDs were the same (redundant)?? If they are different, what do you do, pull over and change the DVD when you get to Dragon territory??
I usually use the phone bu the car NAV is good in areas where phone data is limited... I have original DVDs from my 2010. I should probably look for an update.... so, following this thread....
Old Feb 2, 2017 | 04:08 PM
Cambo's Avatar
Totally different navigation systems, the discs are not interchangeable between an X150 and X350
Old Feb 2, 2017 | 04:15 PM
Sean W's Avatar
Yeah Eastern US and Western. Not sure how Canada is split out.
Old Feb 2, 2017 | 04:16 PM
Sean W's Avatar
assumed as much looking @ the EPC but had to ask. Thanks Cambo.
Old Feb 2, 2017 | 07:21 PM
kj07xk's Avatar
Canada and the midwest are on both disks so there is some overlap.
