Need a part number
Old Mar 31, 2025 | 09:44 PM
powelld91's Avatar
Default Need a part number
My passenger seat belt is twisted, so I need to remove the lower bolt beside the seat that screws into the body frame. The service manual says to discard it and use a new screw.
What I can't determine is the part number for this screw and how to procure it. I think it s a T65 Torx, but can't be sure from the information I found.
Anybody done this and have any guidance they would like to share?
Dan
Old Mar 31, 2025 | 11:23 PM
Cee Jay's Avatar
If your seatbelt is twisted, it's nearly always because it's twisted INSIDE the take-up reel. Pull both top and bottom out as far as possible to the dead-stop. You'll probably find where it got folded somewhere.
Old Mar 31, 2025 | 11:37 PM
OzXFR's Avatar
Almost certain that the instruction to use a new bolt is yer typical OTT "safety" nannies at it again and it would be perfectly OK to reuse the existing bolt.
That said I agree with Cee Jay and it's prolly just a twist inside the reel.
Old Apr 1, 2025 | 02:22 PM
powelld91's Avatar
I'll stretch the belt again to make sure, but I think I did this and didn't find the twist.
As for the bolt, I am sure it is fine. That said, it looks like it might cost $2, so I would just as soon replace it if I had a part number.
JaguarParts.com doesn't appear to list the bolt individually, and I don't need the full assembly.
https://www.jaguarparts.com/v-2010-j...ody--seat-belt
Old Apr 3, 2025 | 12:47 PM
XKDreams's Avatar
Mine is twisted too, has been since I got the kitty last year. I’ve pulled the belt out all the way, and still twisted…how’s that happen?
Old Apr 3, 2025 | 01:03 PM
powelld91's Avatar
i don't know how it happens, but I stretched mine again and it is indeed twisted.
I think the bolt is a 65 Torx and you can probably get to it if you bring the seat forward, so should be simple to resolve.
Old Apr 3, 2025 | 02:34 PM
Cee Jay's Avatar
Maybe only the buckle part itself twisted on the belt so it is weird when coupled to the lock part?
Old Apr 4, 2025 | 11:00 AM
KurtC's Avatar
My passenger-side belt had this same issue when we purchased the car last November. Figured out it was the buckle itself that was reversed. I simply made a shallow-angle fold in the belt, then slid the buckle over the fold until it was reversed on the belt. It's a bit difficult as the slot in the buckle is not much wider than a single layer of the belt. Keep working it and it will go through.
JagMan 98
Oct 26, 2023 07:51 PM
mdroc1
Jul 19, 2021 08:12 PM
Windycityx
Mar 23, 2015 07:29 PM
Mexk8
Mar 16, 2012 05:11 PM
