Need switched +12v 07 XKR
Old Mar 11, 2015 | 04:58 PM
flyc2c's Avatar
Default Need switched +12v 07 XKR
I need to know where I can tap into +12v that isn't on the CANBUS. Current will be nil. I installed my HKS camp2 and the video converter near the battery. I originally tapped off the wires going to the Nav DVD player. The darn thing is hot all the time!!!!! Runs the battery dead if I leave the converter connected. It's no wonder these cars eat batteries.
Somewhere near the back or at the rear fuse panel behind the back seat would be great.
HELP!
Old Mar 11, 2015 | 09:23 PM
WhiteXKR's Avatar
Switched power points are scarce on this car because almost everything is controlled electronically.
There is one for an optional 12 volt outlet in the trunk that Jaguar sells as an accessory.
Remove the left (US driver side) louvered access cover at the rear of the trunk. If you then look at the inner left rear of the trunk, you should see a 3-prong black connector with white-red, brown and black wires attached to the rear surface and not connected to anything. White-Red is switched power and Black is ground. You can actually plug ordinary .250" spade terminals in that connector if you do not want to tap the wires.
If you do not see power there, make sure there is a 10 amp fuse in position F23 of the central junction box.
Old Mar 11, 2015 | 09:29 PM
flyc2c's Avatar
You sir, are the man. You mention "trunk" but I trust Jaguar also put this connector in the coupe.
Thank you!
Old Mar 11, 2015 | 09:42 PM
WhiteXKR's Avatar
The drawings show it for both convertible and coupe. I was describing it for my convertible, but I think it is in roughly a comparable area in the coupe.
mrplow58
Jan 21, 2024 05:53 AM
tonyforman
Sep 10, 2015 07:23 PM
1964Daimler
Sep 9, 2015 11:28 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
laserguy
Sep 3, 2015 02:02 PM
