OBD2 display in ashtray location
Old Sep 20, 2020 | 05:16 AM
  #281
kj07xk's Avatar
Hey hey! ‘Arrived in country’!
Question Bob: Are your updates cumulative, or do they need to be applied in sequence?
Old Sep 20, 2020 | 05:47 AM
  #282
barnsie's Avatar
I was about to ask the same. There aren't any streetlights where I live so I haven't noticed the display hunting as it passes streetlamps. I will probably update anyway, just because... but I wondered if I skipped this one, but wanted a future update, if this latest improvement would be in the future update too. Bob?
Old Sep 20, 2020 | 09:13 AM
  #283
Cabrio Bob's Avatar
Updates are not cumulative, and if you want to go back a few versions that's also possible.
Old Sep 20, 2020 | 09:49 AM
  #284
barnsie's Avatar
Thanks, Bob
Old Sep 20, 2020 | 12:08 PM
  #285
DGL's Avatar
DGL
Thanks. If the updates are not cumulative then I assume each update is for a specific item which successive updates do not include. Consequently, one will need to apply all updates if he or she desires to have everything up to date. I assumed it was cumulative. Good question.
Old Sep 20, 2020 | 12:20 PM
  #286
Cabrio Bob's Avatar
Perhaps cumulative is the wrong word to use here.
Each update has the previous enhancements in them.
If one update is skipped, the next update can be installed without installing the previous update.
Old Sep 20, 2020 | 01:15 PM
  #287
barnsie's Avatar
So, for the avoidance of doubt, if I skip the 'no flickering' update for now, but then there is a future update for xxx, if I install the xxx update, I will also get the 'no flickering' feature as well?
Old Sep 20, 2020 | 02:11 PM
  #288
DGL's Avatar
DGL
My Adu has arrived in Canada, cleared customs, and is with Canada Post in Ontario to be shipped to me in the east coast. I should have it by Thursday.
Old Sep 20, 2020 | 08:27 PM
  #289
DGL's Avatar
DGL
I'll like to suggest an update. Most, if not all, members who bought into this ADU have done so to reduce the catastrophic event of having the engine over heat. If the coolant temperature reached an unsafe temperature, preset or user entered, have the readout flash to alert the user. We have no color change or sound alert option, but this should not be too difficult to implement with a few lines of code.
Old Sep 20, 2020 | 11:21 PM
  #290
Cabrio Bob's Avatar
Yes. a firmware update is a total brainwash. the device has no memory of a previous update.
Old Sep 20, 2020 | 11:31 PM
  #291
Cabrio Bob's Avatar
I'll have a look into this. There may be problems introduced since currently when you select a display other than coolant temperature, this coolant temperature is not polled. What would be the threshold temperature? (if more people respond I'll take the average)
Old Sep 21, 2020 | 05:08 AM
  #292
barnsie's Avatar
IDK what temperature would be considered 'dangerous' but my 4.2 runs anywhere between 92 degrees C and 95 C. It depends on speed, ambient temperature etc. Sometimes, when I am sitting in traffic, it will go up to 96 but I can't recall it going beyond that. I'd say I'd start to get concerned at 100 degrees C. Just my two cents.
I understand the polling issue. 99% of the time in the UK, I have the ADU set to show coolant and volts, so flashing the display would work for me most of the time. The other readouts are, for me, just things I might check now and then. But when I am in France, I will set the ADU to KPH and leave it at that for fairly long time periods. AIUI, if the engine overheats while I am on KPH, the ADU won't 'know' this as it won't be polling coolant temperature. I guess it would have to poll 'in the background' which may be a problem. Nothing is ever simple is it!
Old Sep 21, 2020 | 06:27 AM
  #293
DGL's Avatar
DGL
My 5l SC regularly see's coolant temperature 95 to 98 Celsius. Then when the engine is stopped after being 98 the coolant temperature can reach 103 with no air or water flow. I think a safe temperature setting would be around 108 to 110. We want to be protective after 110 to avoid > 120 Celsius and engine damage. No coolant temperature warnings and an engine with a faulty water pump, and faulty hoses can be disastrous; we all know we have these problems engineered into our engines. This is a situation were the ADU will benefit us the most.
Old Sep 21, 2020 | 10:22 AM
  #294
paulgorringe's Avatar
Hi all
Does anyone else with the ADU find the flashing led lights from the OBD2 wireless device annoying when driving at night?
My whole footwell flashes blue, green and red all the time.
Is there a way of turning these off or maybe put some tape over the unit to stop the distraction?
Old Sep 21, 2020 | 10:24 AM
  #295
Cee Jay's Avatar
Originally Posted by paulgorringe
Hi all
You already answered this yourself.
Old Sep 21, 2020 | 10:30 AM
  #296
Cabrio Bob's Avatar
Hi all
Mine does the same, but after a couple of minutes my eyes are on the road and I don't notice it any more.
Indeed (black) tape is a good remedy.
Old Sep 21, 2020 | 10:38 AM
  #297
Cabrio Bob's Avatar
Now working on a code that will notify you when the coolant temperature has arrived above a certain value:
When in coolant/volts mode, the coolant temperature changes into a different colour (or flashes, maybe better)
When other screens are displayed, a BIG yellow dot flashes on the screen every ~0.5 seconds.
For test purposes, I'll set the threshold temperature low so we can see if it works, later the threshold will be set to an xxx value.
Code:
float coolError = 104; // enter the coolant error temperature (use only °C)
Old Sep 21, 2020 | 10:57 AM
  #298
Cabrio Bob's Avatar
Default 2nd round ??
I've had numerous requests about a 2nd round.
Currently all I can say is:
Keep an eye on this thread, in a couple of weeks there will be more news about that (when round 1 is completely delivered / finished).
Old Sep 21, 2020 | 12:02 PM
  #299
[QUOTE=Cabrio Bob;2291670]Driving around at night, I noticed when passing street lights, the display of the device flickers, which I found to be annoying.
So I updated the firmware again, which smooths out the change in brightness of the display.
Now downloadable from my website.
After updating yesterday I can confirm that driving in the dark this morning, passing under many street lights There was absolutely no flickering of the screen
Another great contribution from Bob
Old Sep 21, 2020 | 12:45 PM
  #300
MarkyUK's Avatar
If this product were a commercial venture costing £££/€€€/$$$ I could understand the demands of users.
Given this was the price it was I've no unreasonable requests for Bob. IMO he is immensely proud of his baby and will never say no.
The question is, should we ask?
I am happy with Bob's solution out of the box and am also happy to PAY a few £'s for future enhancements...are you?
