OBD2 display in ashtray location
Old Sep 24, 2020 | 10:33 AM
  #341
DGL's Avatar
DGL
I have an 64bit surface pro 6. I downloaded the firmware twice. However, it gave be a warning of possible virus and I proceeded. I will try again...
  #342
Cabrio Bob's Avatar
Continue with a list:
- remove the ESP32 from the device and flash it from there
- the ESP32 is defective ( a different computer should verify this)
- surface pro ... that's tablet right? maybe that's the problem.
Old Sep 24, 2020 | 10:48 AM
  #343
DGL's Avatar
DGL
I'll try on another laptop laptop
Old Sep 24, 2020 | 10:57 AM
  #344
DGL's Avatar
DGL
I downloaded the update again, but I don't see the .bat file. I opened the folders.
Old Sep 24, 2020 | 10:59 AM
  #345
DGL's Avatar
DGL
Need to wait to get the password from the wife. I'll keep trying on my surface pro 6
  #346
Cabrio Bob's Avatar
on the other laptop? And did Windows see it as a virus and quarantined it ....?
- ok lets wait for that
Old Sep 24, 2020 | 11:06 AM
  #347
DGL's Avatar
DGL
How do I remove ESP32?
surface pro is Microsoft's laptop/tablet running windows 10 (PC)
Old Sep 24, 2020 | 11:10 AM
  #348
Cabrio Bob's Avatar
at the back of the device where the display is sticking out, just above that push the black bar with a small screwdriver, the lid can be taken off,
then remove the electronics (not fully - the USB cable prevents this) , flip it over and you can take off the ESP32 by pulling it away from the electronics pcb (mind the orientation when putting it back again)
But first try the other laptop...
Old Sep 24, 2020 | 11:21 AM
  #349
DGL's Avatar
DGL
There should not be a problem with my Microsoft surface pro 6. It is a PC running windows 10. Will I need to remove the ESP32 every time I need to update? I'm really not interested in taking the device apart. If the ESP32 is defective wouldn't it be good to replace it?
Old Sep 24, 2020 | 11:24 AM
  #350
Cabrio Bob's Avatar
Because the "firmware.bat" file was vanished, I think your sufrace pro treats it like a virus, thus not working properly.
In Windows Defender you could allow the bat file from doing it's thing.
But let's see what the other laptop does.
Old Sep 24, 2020 | 11:28 AM
  #351
Cabrio Bob's Avatar
or, copy and paste the below code into notepad, save it as a BAT file in the same folder next to the firmware bat file and try to run that.
it's the same as the firmware.bat file but will cause a slower upload to the ESP32 (maybe speed is a problem)
Code:
@echo off
setlocal enabledelayedexpansion
Echo.
REM Echo Files extracted
PING localhost -n 2 >NUL
Echo.
Echo This version will flash the device for 5.0 models
Echo.
Echo List of COM ports available:
Echo.
wmic path win32_pnpentity get caption /format:table| find "COM"
Echo.
PING localhost -n 3 >NUL
set "HardwareID=VID_10C4&PID_EA60"
set "RegistryPath=HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\USB"
set "ProductName=Silicon Labs CP210x USB to UART Bridge"
set "DeviceFound=0"
Echo.
for /F "delims=" %%I in ('%SystemRoot%\System32\reg.exe QUERY "%RegistryPath%\%HardwareID%" 2^>nul') do call :GetPort "%%I"
if "%DeviceFound%" == "0" echo WARNING: Could not find any connected %ProductName%.
Echo.
endlocal
pause
goto :EOF
:GetPort
set "RegistryKey=%~1"
if /I not "%RegistryKey:~0,71%" == "%RegistryPath%\%HardwareID%\" goto :EOF
for /F "skip=2 tokens=1,3" %%A in ('%SystemRoot%\System32\reg.exe QUERY "%~1\Device Parameters" /v PortName 2^>nul') do (
if /I "%%A" == "PortName" set "SerialPort=%%B" && goto OutputPort
goto :EOF
:OutputPort
%SystemRoot%\System32\reg.exe query HKLM\HARDWARE\DEVICEMAP\SERIALCOMM | %SystemRoot%\System32\findstr.exe /E /I /L /C:%SerialPort% >nul
if errorlevel 1 goto :EOF
set "DeviceFound=1"
set "DeviceNumber=%RegistryKey:~-1%"
Echo Programmed device will be: %ProductName% on %SerialPort%.
Echo.
pause
CLS
:MENU
Echo.
Echo Version 2.1.0.5
Echo.
Echo ------------------------------------------------------
Echo PRESS 1, 2, 3 or 4 to select your units, or 5 to EXIT.
Echo.
Echo 1 - Celsius + Kilometers
Echo 2 - Celsius + Miles
Echo 3 - Fahrenheit + Kilometers
Echo 4 - Fahrenheit + Miles
Echo 5 - Exit
Echo.
SET /P M=Type 1, 2, 3, 4 or 5 then press ENTER:
IF %M%==1 GOTO C_K
IF %M%==2 GOTO C_M
IF %M%==3 GOTO F_K
IF %M%==4 GOTO F_M
IF %M%==5 GOTO EOF
:C_K
CLS
Echo.
Echo.
Echo you have chosen Celsius + Kilometers
Echo.
bin\esptool.exe --chip esp32 --port %SerialPort% --baud 115200 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 bin\boot_app0.bin 0x1000 bin\bootloader_dio_80m.bin 0x10000 bin\CK.ino.bin 0x8000 bin\CK.ino.partitions.bin
Echo.
Echo Cleanup temporary files ....
Echo.
Echo Finished ^^!
Echo.
GOTO MENU2
:C_M
CLS
Echo.
Echo.
Echo you have chosen Celsius + Miles
Echo.
bin\esptool.exe --chip esp32 --port %SerialPort% --baud 115200 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 bin\boot_app0.bin 0x1000 bin\bootloader_dio_80m.bin 0x10000 bin\CM.ino.bin 0x8000 bin\CM.ino.partitions.bin
Echo.
Echo.
Echo Finished ^^!
Echo.
GOTO MENU2
:F_K
CLS
Echo.
Echo.
Echo you have chosen Fahrenheit + Kilometers
Echo.
bin\esptool.exe --chip esp32 --port %SerialPort% --baud 115200 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 bin\boot_app0.bin 0x1000 bin\bootloader_dio_80m.bin 0x10000 bin\FK.ino.bin 0x8000 bin\FK.ino.partitions.bin
Echo.
Echo.
Echo Finished ^^!
Echo.
GOTO MENU2
:F_M
CLS
Echo.
Echo.
Echo you have chosen Fahrenheit + Miles
Echo.
bin\esptool.exe --chip esp32 --port %SerialPort% --baud 115200 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 bin\boot_app0.bin 0x1000 bin\bootloader_dio_80m.bin 0x10000 bin\FM.ino.bin 0x8000 bin\FM.ino.partitions.bin
Echo.
Echo.
Echo Finished ^^!
Echo.
GOTO MENU2
:MENU2
pause
GOTO EOF
:EOF
EXIT
Old Sep 24, 2020 | 11:31 AM
  #352
DGL's Avatar
DGL
If windows defender is interfering I can turn it off to see if that helps. Would this help?
Old Sep 24, 2020 | 11:33 AM
  #353
Cabrio Bob's Avatar
if that is the cause - yes
Old Sep 24, 2020 | 11:39 AM
  #354
Cabrio Bob's Avatar
Taking a break, watching my soccer team on TV ....
Old Sep 24, 2020 | 11:56 AM
  #355
DGL's Avatar
DGL
created the .bat and get this:
Old Sep 24, 2020 | 12:00 PM
  #356
barnsie's Avatar
FWIW I also got a warning that the file was a virus or trojan. Knowing that it isn't, I clicked through and ran it anyway and it worked fine. In the past I have had to disable all anti-virus protection in order to run some stuff similar to Bob's program. It's worth a try as it is easy, free and 100% reversible if it doesn't do the trick.
Also, are you running the firmware,bat file from inside the ZIP? Bob said this was a no-no and the ZIP should be unzipped to a folder and the batch file run from there. Just random thoughts. Apologies if you have tried these things already.
Old Sep 24, 2020 | 12:11 PM
  #357
barnsie's Avatar
The error message means you have invalid paths in the path environment - for example, folders which no longer exist. So the batch file is attempting to use a directory it cannot find. Check the full paths for logic and see if that yields a clue. Have you tried moving the ZIP file to the desktop, creating a new folder and then unzipping Bob's file into it? Then swap to that new folder and run the batch file directly from there. Again, apologies if you have already done all this.
Old Sep 24, 2020 | 12:13 PM
  #358
DGL's Avatar
DGL
Woo hoo...it worked on a different laptop. What is the reason for this? I'll like to use my surface pro 6 for updates.
Old Sep 24, 2020 | 12:22 PM
  #359
barnsie's Avatar
Yay! Is the other laptop using the same hardware and OS software configuration and the same anti-virus software? Are there any obvious differences - eg you used a USB 2.0 port or a USB 3.0 port? Did you use a different USB cable as well or the same? Is the Windows version identical on both machines? Was your procedure any different on either machine - eg how and where you unzipped the .ZIP file? There could literally be hundreds of reasons. Short of doing a lot of detective work on the Surface Pro, the easy solution is to do the update on the alternative machine. It isn't likely to be something we will have to do repeatedly, I guess.
Glad you got it done in the end, regardless of how. So, have you installed the ADU in your car yet?
Old Sep 24, 2020 | 12:24 PM
  #360
barnsie's Avatar
I think that is the best in-situ photograph yet. Bob should use this photo in his marketing (Or at least on his user manual cover etc, with your permission of course).
