oil pressure
Old May 31, 2014 | 08:22 PM
carlprs's Avatar
Default oil pressure
i'm looking into the elm 327 bluetooth set up. In looking at past posts it seems like there is no oil pressure input sensor to the OBDII. Is that true? Does anybody have an idea where in the oil gallery one could be installed?
Old Jun 1, 2014 | 08:26 AM
jagtoes's Avatar
I do not believe you can buy an oil pressure sensor that would work through the OBDII system connector. I have to believe there is a way that the factory can tap into a fitting (like the low oil pressure warning switch) and install a OP sender which you can attach to a gauge either in the engine compartment or located in the cockpit. When I had an OP issue on my Fcar I installed a parallel gauge to verify the electronic gauge was reading correctly (see pic).
bamforp
Aug 14, 2024 05:36 PM
99xk8guy
May 28, 2024 09:36 PM
jerry_hoback
XJ40 ( XJ81 )
Sep 13, 2015 07:48 PM
mhamilton
Sep 12, 2015 03:21 PM
giandanielxk8
Sep 6, 2015 07:21 PM
