oil sump plug washer
The complete drain plug with seal for the X150 is:
4.2 litre - P/N AJ83017
5.0 litre - P/N AJ88461
JLR do not list the seal separately and both drain plugs are currently showing as out of stock. All the usual sources are showing "subject to availability" which suggests more of us will have similar difficulty finding replacements.
This aftermarket supplier shows equivalent drain plugs for both types:
4.2 - https://www.sparepartstore24.co.uk/12831606-triscan
5.0 - https://www.sparepartstore24.co.uk/7869678-fa1
Digging further into the same website returns the seal for the 5.0
https://www.sparepartstore24.co.uk/j...in-plug-gasket
This gives the dimensions as:
External Diameter: 22.4mm
Internal Diameter: 13mm
Thickness: 3mm
Unfortunately, I can't find the equivalent for the 4.2 listed there. However both plugs are M14 so the seal could be identical. If you are completely stuck for a seal, it's not going to cost a fortune to source one to these dimensions locally and give it a try.
Thickness: 3mm
Please let us know how it goes. It's always annoyed me to throw away a perfectly good plug when all it needs is a new washer.
I've re-used the same plug and washer several times now. I don't see the point unless the washer is totally flattened or coming apart. Never had a leak or issue.
Do people really replace it every time??
try the ford dealer, maybe they have an engine that uses an m14x1.5 drain plug. most of them are m12x1.75
Replaced the drain plug on my 4.2 (and the other cars in the family) with a Fumoto valve.
No more washers to replace, just turn the little lever, and out comes the oil.
Yes.. Me too. I've been going for the extra bucks and letting Jaguar take me over the coals to have the oil sucked out. No plug or washer shortage issue here, just lighter pockets.
There appears to be a FORD part number for these: 1 005 593
https://www.ebay.com/itm/171286130407
Might be worth asking a local dealer.
Both come up as the same item if you look at aftermarket cross references and they are also used on many other cars (Ford, Volvo, Citroen, Peugeot, Mazda) including Transit vans! They cost peanuts and will probably be available decades to come
orangeblossom
May 19, 2016 12:07 AM
