It was only a matter of time!!! Coolant Leak
Old Aug 5, 2020 | 01:00 PM
TexasTraveler's Avatar
Default Deleted
Deleted
Old Aug 5, 2020 | 04:28 PM
Cee Jay's Avatar
So, No Leak or something blew up?
Old Aug 6, 2020 | 10:33 AM
So I cleaned up the entire engine and while doing so, I have determined that the green fluid which I now know is coolant, even though it looks orange in the reservoir and container, leaked from the heater core connector. Connector has a lot of play in it, more than I would think it should have, but not in a slop kind of way, but in the on/off direction. I was able to push it on at least a 1/4"-1/2", not sure if that will make any difference. I am sure there is an o-ring in there for a seal, so I am going to watch that area and see how much fluid I loose, most likely will need to replace the o-ring. All the stuff on the top of the trans was just leftover foam soap from car wash...
Old Aug 6, 2020 | 01:22 PM
Cee Jay's Avatar
Sorta like this?
Old Aug 6, 2020 | 01:38 PM
See the red arrow here... That fitting seems to have a small leak and is dripping down and collecting on surface of the plastic fitting below it. At least I think that's whats happening...
Old Aug 6, 2020 | 02:55 PM
trkyam's Avatar
more likely its the water outlet pipe at the back of the engine just under that.
Not hard to change, and they fail often, that pipe takes ALOT of heat and pressure
ricardoa1
May 3, 2020 02:51 PM
Fernando
Sep 24, 2017 05:38 PM
elic9
Aug 17, 2016 12:27 AM
Isoruku
Jun 25, 2016 09:56 AM
Greggbhill
Dec 24, 2015 02:24 PM
