Overhead light consol
Old Nov 29, 2023 | 03:53 AM
markva44's Avatar
Default Overhead light consol
I want to change the bulbs in the overhead light cluster but cant find a way to remove the cover without the fear of breaking something. Has anyone removed the cover off to change the interior light bulbs?
Old Nov 29, 2023 | 04:44 AM
guy's Avatar
guy
Easily done. Just pull the whole console down from each side, at the back. There are clips that are designed to release with enough pulling .
Old Nov 29, 2023 | 10:19 AM
Bill400's Avatar
The plastic is getting brittle with age. Consider using a plastic trim tool and proceed as Guy advised.
Old Nov 29, 2023 | 10:32 AM
markva44's Avatar
Thanks for the reply, when you say back do you mean towards the windscreen or the bit nearer me?
Old Nov 29, 2023 | 02:19 PM
guy's Avatar
guy
nearer the rear of the car
Old Nov 29, 2023 | 04:58 PM
McJag222's Avatar
It pulls straight down basically, use some pry tools to ease it down.
Old Nov 29, 2023 | 05:14 PM
Sean W's Avatar
you can see where the clips are in this post:
https://www.jaguarforums.com/forum/x...8/#post2127473
Old Nov 29, 2023 | 05:38 PM
McJag222's Avatar
Pic from dat ^ thread with clips outlined:
Old Nov 29, 2023 | 07:47 PM
Tracee's Avatar
  1. Was always puzzled about those small grilles on either side. Thought they would've been a better location for the hands-off microphone(s) rather than adding that "wart" on the A pillar. Read somewhere that they might be for the Intrusion Sensors on Euro models. If ever I re-upholster my interior, I'll move the microphone up there and delete the wart.
Old Nov 29, 2023 | 07:51 PM
Cee Jay's Avatar
I was told they were proximity sensors to help control the SRS. Intrusion Sensors also makes sense as they'd both do the same thing.
Old Nov 29, 2023 | 08:34 PM
McJag222's Avatar
The intrusion detection modules are an optional fitment in some markets and are not available in
other markets. Two intrusion detection modules are fitted. One module is located on the front of the
floor console and monitors the front seat area, the second module is fitted at the rear of the floor
console and monitors the rear seat area. The modules are wired together in parallel with the forward
module being the master and the rearward module being the slave module.
Each intrusion detection module comprises two microwave sensors which allow the interior of the
vehicle to be monitored. The intrusion detection modules also monitor the vehicle interior on soft
models when the soft top is down.
Looks they just plugged 'em up - must have had something in mind:
top models when the soft top is down.
sony2000
Oct 10, 2023 11:27 AM
lunatic_fringe
Jan 12, 2018 08:14 PM
Scot X300
Dec 22, 2011 12:38 PM
patfr275
Nov 19, 2011 08:32 PM
jagxkrtoofast
Feb 13, 2010 05:49 PM
