P0028-77 : Intake valve Control Solenoid Circuit Range/Performance Bank 2
Old Nov 15, 2020 | 03:29 PM
Paulo Sérgio's Avatar
Default P0028-77 : Intake valve Control Solenoid Circuit Range/Performance Bank 2
Any idea about this error P0028-77 : Intake valve Control Solenoid Circuit Range/Performance Bank 2. It's a urgent subject? Any risk on this?
Many thanks
Old Nov 15, 2020 | 11:36 PM
gkubrak's Avatar
Check your oil. Check your battery voltage too.
If you clear the code does it come back again?
Old Nov 16, 2020 | 09:25 AM
During first pandemic months Jaguar official shops, near my home, was closed, so i decided to change fluids with a referenced mechanic in a local shop.
Oil (filters and other stuff) were changed and filled with Jaguar correct references. This code appeared during local shop tests, not on car dash but on odb scanner from local shop.
As they aren't jaguar specialist i don't know if i must schedulle another additional maintenance with Jaguar. Local mechanic said,that sensor must be change ..how i can check on car dash for this error code? Do i have any kind of risk (motor or other) driving with this sensor failure...
voodooskyline
Oct 11, 2020 08:08 AM
daw90
Apr 21, 2018 08:10 PM
scarbro2011
Dec 28, 2017 11:07 AM
scottpeterd
Apr 3, 2016 09:07 AM
randyb
May 9, 2012 11:32 AM
