Parasitic Current Draw Experience
Old Mar 10, 2021 | 08:06 PM
Cee Jay's Avatar
My F150 is at an automotive electrical specialist shop because of parasitic drain. It's been there two days and no call back, and the guy said he'd start on it right away.
I don't feel too good about this...
I tried the millivolt check, but it was tedious and quite finicky. I didn't have a working amp clamp at the time so that was a no-go also. This shop has an amp meter with troubleshooting software, so it'll be (hopefully) easier to find something. Plus, it's still winter and I'm allergic to cold.
Old Aug 16, 2021 | 03:21 PM
panthera999's Avatar
So, I finally fixed the power supply.
The original suffered from my bad soldering, so I couldn't trust it. Only $25, so tossed it.
Got a new one, plus a much more precise soldering kit for surface mounted devices.
Modified it as I should have done in the previous one, but stopped at upgrading it to 13.5V. Got the right cables, bolts and so forth. Done, works fine.
Now I can reprogram and re-option without voltage concerns.
(Oh, BTW, shutting off climate and double locking: no parasitic drain in 6 months.)
Had fun and learned a lot (which is what I bought the XK to do)
Finished, finally. 13.5 VDC
Old Aug 16, 2021 | 04:22 PM
fxdwg's Avatar
Is that power supply fused someplace?
Old Aug 16, 2021 | 05:19 PM
Yes, see attached.
Old Aug 17, 2021 | 07:24 AM
Sovejag13190's Avatar
hi 034A is hot and i think that is a bulb on that create this value. See trunk bulb or door bulb if there are no on when car is cut.
alexander thegreat
Mar 31, 2021 11:06 AM
jagtoes
Jan 12, 2019 03:24 PM
Donaldmolsen
E type ( XK-E )
Sep 3, 2014 04:07 AM
Ngarara
Mar 29, 2014 09:58 PM
lcotelaw
Jan 30, 2014 08:22 AM
