Part numbers for rear subframe isolator bushes
Old Mar 7, 2022 | 08:07 AM
jahummer's Avatar
Default Part numbers for rear subframe isolator bushes
Without using google, can anyone confirm the correct part numbers for the 3-4 differential isolator bushes? The only numbers I could find were for the S-type - XR818453, C2C1780, C2C822, XR813260 and XR818452
Old Mar 7, 2022 | 08:31 AM
Sabrinaservicewriter's Avatar
Default More XKR Rear axle part number
Good Morning Jahummer!
I did a quick search using our parts distributors look up system and found these two insulator part numbers: C2C16377-Differential Mount Insulator & C2C8221-Differential Housing Insulator. Hope this helps!
Additional Notes: Not sure if you need these but this is from our parts look up system we use. Grant it, a lot of parts on here get superseded.
Rear Axle
Axle Seals
Side Seals- XR821244
Pinion Seal- C2S52518
Companion Flange- C2C32944
Last edited by Sabrinaservicewriter; Mar 7, 2022 at 08:38 AM. Reason: Additional notes
Old Mar 7, 2022 | 08:47 AM
Bill400's Avatar
XK/R Rear suspension bushings
Old Mar 7, 2022 | 09:37 AM
Bill400's Avatar
XKR shown XK similar for bushings
XKR Differential Bushings
  • 8. Insulator
  • differential
  • LH upper
  • From VIN (B32753) To VIN (B48619)
  • 5.0 Litre supercharged
  • C2P15558, quantity on the car 1 pc.
  • From VIN (B48620)
  • RH upper
  • C2P15557, quantity on the car 1 pc.
  • From VIN (B48620)
XK Differential Bushings
  • 5. Insulator
  • differential
  • LH lower
  • From VIN (B48168)
  • C2D45334, quantity on the car 1 pc.
  • LH upper
  • To VIN (B48167)
  • C2P13646, quantity on the car 1 pc.
  • To VIN (B52040)
  • 5.0 Litre naturally aspirated
  • Other Option
  • RH lower
  • From VIN (B48168)
  • C2D45333, quantity on the car 1 pc.
  • RH upper
  • To VIN (B48167)
  • C2P12732, quantity on the car 1 pc.
  • To VIN (B52040)
  • Other Option
XK 4.2L
  • 9. Insulator
  • differential
  • front upper
  • C2C8221, quantity on the car 1 pc.
Old Mar 7, 2022 | 09:50 AM
Bill400's Avatar
jahummer,
I really appreciate your question and your X358 "Rear Subframe Bushes" post that popped up below.
I've been waiting for mild weather to look for suspension noises. You have provided a lead to a very likely source.
Thank you very much.
best regards,
Bill
Old Mar 7, 2022 | 03:56 PM
jahummer's Avatar
The rear diff isolators were in stock at the main dealer half of the front diff isolator was in stock. All other part numbers were NLA which I'm seeing more and more for all JLR vehicles.
Old Sep 16, 2022 | 05:20 PM
Sportston's Avatar
When rubber bushings are NLA you can make your own from liquid polyurethane and hardener. Or purchase universal polyurethane top-hat bushes.
MCFastybloke
22
Mar 3, 2022 08:44 AM
Bumble7755
Jul 20, 2020 03:32 PM
Melb2018
Jul 10, 2019 12:15 AM
Jagluvr
Jun 7, 2018 04:47 PM
