XK 5.0 N/A max speed
Old Sep 15, 2022 | 02:33 PM
sanguszko's Avatar
Default XK 5.0 N/A max speed
What's the max speed x150 5.0 N / A? The catalog is 250 km / h, but mine reached 263 and kept walking but I gave up
Old Sep 15, 2022 | 04:50 PM
SeanU's Avatar
The official # is based on ecu limited speed when in 6th gear... but apparently if you keep it in 5th the limiter is rev based, not speed. Apparently the front end starts to lift at higher speeds... and if you look at the XKR models with higher limits, there are aero changes to help downforce.
Old Sep 16, 2022 | 11:31 AM
wymjym's Avatar
I'm wondering out loud here, since the xkr have air vents in the hood is it reasonable to consider that the air that is forced into the engine compartment at speed could contribute to front end lift and that the vents not only help dissipate engine heat but also reduce the air pressure and lift?
wj
Old Sep 16, 2022 | 05:30 PM
jahummer's Avatar
Actually, Jaguar have done an excellent job of engineering airflow. The bonnet vents along with ducts and under-tray provide a good balance of air flow and aerodynamics. The R-S GT version had larger bonnet venting, from the R version and then further up towards the windscreen, provider improved airflow and aero (along with canards and front splitter). Whilst the X150's capable of higher speed, it's mainly for show as it's original intent's still a GT tourer and not a true sports.
welldigger
XK120 XK140 XK150
Nov 12, 2021 09:52 PM
Xk646
Dec 29, 2020 10:08 PM
steve_k_xk
Oct 6, 2016 02:36 AM
gragner66
Sights N Sounds
Jul 6, 2011 08:04 AM
Fla Steve
Mar 3, 2011 09:08 PM
