XK120 XK140 XK150 1948 - 1962
XK 140 5 speed conversion
Old Oct 31, 2021 | 06:56 PM
welldigger's Avatar
Default XK 140 5 speed conversion
I purchased an xk 140 DHC and plan to dismantle and restore it. I’m sure I will be asking quit a few questions as there is a tremendous amount of knowledge here and I thank you all in advance. I will start with two questions and I am sure there will be varying opinions. What is the best 5 speed gearbox that would require the least amount of modifications and best front disc break conversion.
Old Nov 3, 2021 | 05:32 AM
jaguar38s's Avatar
I got the Brake conversion for my XK140 from SNGBarratt.
On my XK150 I converted to a 5 speed gearbox from Guy Broad ( The Broadspeed direct bold on version ).
For all gearbox conversions you need to go to a diafragma Clutch ( 91/2" ), Therefore redrilling the flywheel is needed.
Old Nov 11, 2021 | 10:39 AM
denniswhite's Avatar
Here in California and just finishing the restoration of a 140. I'm not a wrench, but the Tremec 5-speed was highly recommended (and installed), and upgraded just the front brakes to Brembo discs. I understand the Guy Broad conversion for the gearbox is excellent, but have heard of troubles with the Getrag. Hope this helps.
Old Nov 12, 2021 | 09:52 PM
welldigger's Avatar
Thank you for the tips, gives me some direction need to find best place to purchase then find an engine rebuilder. I can easily go anywhere on the west coast as I live in Washington
Xk646
Dec 29, 2020 10:08 PM
sevenlima
Aug 14, 2015 04:14 AM
gragner66
Sights N Sounds
Jul 6, 2011 08:04 AM
Fla Steve
Mar 3, 2011 09:08 PM
