Please help with 12' xkr codes
Old Jul 28, 2021 | 09:55 PM
Or.XKR's Avatar
Default Please help with 12' xkr codes
Hello everybody....
1st time posting...
My 2012 xkr started running a little rough, figured it was time for a tune up.... then after two weekend trips of maybe 120 miles the restricted performance light came on and it started running really rough. I scanned it and it came back with 6 codes. I will attach screenshots of codes....any help or advise on this would be much appreciated. Thanks in advance.
Old Jul 29, 2021 | 08:07 AM
Rummy636's Avatar
P0019-00 Crankshaft Position - Camshaft Position Correlation - Bank 2 Sensor B - No sub type information NOTE:- Circuit VFS_EX_B -
  • The relative positions of the crankshaft position sensor and camshaft timing plate teeth are not correct
  • Engine timing incorrect
  • Timing chain installed incorrectly
  • Variable valve timing forced fully advanced
  • Check engine timing. Check camshaft sensor timing plate is installed correctly. Check timing chain is installed correctly
radiatn
Jul 2, 2021 04:45 PM
Darrinj123
Mar 29, 2020 12:28 PM
resonic
Photography
Apr 1, 2016 01:27 PM
Fiacre
Photography
Nov 19, 2012 02:07 PM
