Plug and P0308
Old Jul 15, 2023 | 03:14 PM
Canadacat's Avatar
Default Plug and P0308
Pic of plug looks good to me why would i be getting a po308
Old Jul 15, 2023 | 03:32 PM
McJag222's Avatar
Ignition coil? I changed all four plugs and coils on one bank.
It looks a bit lean on mixture (could be just the photo itself being a bit brighter) - here's one of mine with is a nice rich colour:
Old Jul 15, 2023 | 03:53 PM
Canadacat's Avatar
Put the plug back in but changed the coil. Plugs have less tgan 5000 on them. I guess i have to drive it and see if it comes back. I think it has something to do with my cat getting bad , might be back pressure affecting it on full throttle. Vacuum is constant at idle, think that is ok.
thx
Old Jul 15, 2023 | 04:00 PM
McJag222's Avatar
thx
Cee_Jay used some cat cleaner after an issue with a fuel injector I think. He said it worked. Might be worth a try if you think there is a cat problem. I bought some from Canadian Tire but haven't used it.
Might be worth sicking some injector cleaner in the tank just in case that injector is acting up a bit.
Old Jul 15, 2023 | 04:04 PM
Canadacat's Avatar
Tried, twice . Car has ran great even with the p0430 but niw going into restricted performance p0308 , might be a glitch who knows byt i know the catalytic has to go. Got a cheap one from rock auto coming .My car is basically a weekend car so don't require a 2000 factory catalytic installed.
Old Jul 15, 2023 | 06:42 PM
Cee Jay's Avatar
The cat cleaner DID work, for about a year and a half. The MIL came back and using the cleaner again did not help. I DID find a more involved procedure to clean them directly spraying on the media through the O2 sensor hole. I will try that next.
Old Jul 15, 2023 | 07:23 PM
Canadacat's Avatar
McJag i will try some injectir cleaners, cant hurt.
Old Jul 16, 2023 | 10:32 AM
Canadacat's Avatar
Getting multiple misfire s now believe it is catalytic related will update after i get it changed.
Old Jul 18, 2023 | 02:03 AM
JagV8's Avatar
In case of web searching it's a 0 not an o: P0308
Old Jul 18, 2023 | 02:47 AM
Pic of plug looks good to me why would i be getting a po308 .....
Because a faulty spark plug is NOT the only possible cause of P0308. Here's the relevant section from the Workshop Manual:
Although X150 uses extended DTC coding (1 Alpha + 4 Numeric + 2 Numeric), there are no extensions defined by Jaguar for P0308.
tolson
Apr 16, 2023 05:39 PM
Andis28
May 27, 2021 04:21 PM
Darren9090
Dec 15, 2016 08:59 PM
grogers1
Jun 18, 2014 02:47 PM
bogart
Nov 23, 2010 04:55 PM
