Quick disconnect o-ring
Old Aug 1, 2023 | 02:11 PM
mhminnich's Avatar
Default Quick disconnect o-ring
Hi folks. I am looking for the o-ring/seal that is part of the quick disconnect hose on the 4.2 XKR coolant crossover manifold. This is the hose secured with the metal retaining clip. If you've been there you know which one I'm talking about.
My seal was knackered so I replaced it with an Ace Hardware o-ring that is about a 98% fit. That leaves me with a slight coolant weep.
Has anyone sourced the or-ring without the hose itself (thanks JLR), or found a good alternative?
Old Aug 1, 2023 | 02:27 PM
Aarcuda's Avatar
I went to Amazon and bought two different o ring kits. one Must have 40 different O-rings and both metric and standard sizes in both thin ank thick cross sections and then I bought another set which was just metric sizes And between those I always seem to be able to find the right size O-ring that I need. I didn’t have any luck going to hardware stores because their selection is limited
Brtiii
May 9, 2023 03:42 AM
Mike1967
Jan 25, 2023 01:57 PM
mott
Jan 21, 2022 04:37 AM
radiatn
Sep 26, 2016 09:39 PM
