Quick disconnect o-ring
Hi folks. I am looking for the o-ring/seal that is part of the quick disconnect hose on the 4.2 XKR coolant crossover manifold. This is the hose secured with the metal retaining clip. If you've been there you know which one I'm talking about.
My seal was knackered so I replaced it with an Ace Hardware o-ring that is about a 98% fit. That leaves me with a slight coolant weep.
Has anyone sourced the or-ring without the hose itself (thanks JLR), or found a good alternative?
I went to Amazon and bought two different o ring kits. one Must have 40 different O-rings and both metric and standard sizes in both thin ank thick cross sections and then I bought another set which was just metric sizes And between those I always seem to be able to find the right size O-ring that I need. I didn’t have any luck going to hardware stores because their selection is limited
