Radar sensor warning
The other day while driving home in the rain, the big yellow triangle warning showed up on the dash stating that I had a Radar Sensor block. The warning disappeared as quickly as it showed up, but I didn't know what its function was or how I unblock it. Searching through the forum's posts I only saw one reference in the XF forum to a similar issue but no replies to the poster's inquiries. I am assuming the radar is related to the adaptive cruise control (which I have never used), and has now self corrected, but was just wondering if anyone else has experienced this?
Although I don't have the ACC on my vert; I did have it on a 2004 XJR. The manual states do not use the ACC in rainy or snowy weather because the radar sensor can be blocked. That is probably what happened to you.
I have never used cruise control, adaptive or otherwise, ever in my life on any car, so this happened without cruise control being activated. However, there was a steady but hardly torrential rain.
LemMe guess.... Sliver Jag?
Yup....
Common, although I don't recall it extending to 2010.
Jaguar had a firmware update to help, as well as having the sensor aligned to a slightly different angle. Cant recall the TSB, but Ill see it I have it on file.
As Ralphwg says, If your driving in bad weather, it is a 'feature' built in by Jaguar to disable it.
Vince
Verified TSB # JTB00086 covered my car, but it says it applies to 2007 - 2008 model years.
I still think a lot of it has to do with the additional reflective silver in out paint, but cant prove it. Even after the updates, my XK kicks off for no visible reason
Yup....
Vince
