Rattle Clunk front end Dealer Response
Old Jul 17, 2013 | 03:22 PM
XKGuy's Avatar
Default Rattle Clunk front end Dealer Response
Rattle and clunk from front end over bumps.
Dealer installs "shim kit" as per bulletin. Issue mininalized but not resolved. Now diagnosis is now that its the calipers??
PS Also intermitent low brake pad warning light??
Any thoughts/opinions?? XKR still at dealer. My confidence in the dealer is quite low. DIAGNOSTIC ABILTIES SEEM SO INADEQUATE.
Old Jul 17, 2013 | 05:17 PM
Posted in the XK8/XKR section. I've moved it to XK/XKR section for you.
Old Jul 17, 2013 | 05:55 PM
GaryinOregon's Avatar
I had this issue on my Stype and the tire company installed the wrong pins that held the pads in place. they tried a couple of types and finally got a strong enough pin to hold them in place to keep them from clattering over bumps. Was very annoying.
Old Jul 17, 2013 | 08:29 PM
DGL's Avatar
DGL
I hate hearing stories like this about the XK and the lack of professional service by Jaguar. I sold my 175 with 6,000 miles and miss it so much I'm looking at a new XK R-S but I get worried when I hear about so many problems and no service or recall.
Old Jul 20, 2013 | 03:08 PM
Dnjaa's Avatar
My left front brake grabs and makes a creaking noise just as the car comes to a final stop. should I be concerned about this? David.
Old Jul 20, 2013 | 06:40 PM
Doug's Avatar
Some clunks-rattles-things that go bump in the night are easy to trace and repair. Others...not so much. Noise travels thru a car in such strange ways. Electronic ears were often useful..and sometimes not.
From my dealership days I can remember going as far as removing bumpers, fenders, dashboards, subframes, and even windshields, and other extensive measures, to track down odd noises.
The next car in with a funny noise might be fixed in 15 minutes
A couple years ago I was fed up with several odd noises on my XJR and spent....and I'm quite serious here...over 50 hours labor tracking them down.
If the dealer is giving your car the sunshine treatment then get on 'em to keep their shoulder to the wheel. Otherwise, be as patient as possible
Do keep abreast of what they are doing. Dependant on how bad the noise is, and your tolerance for it, you might wanna "opt out" of any overly invasive efforts to repair it. I always informed customers ahead of time and let them know if we exhausted the easy possibilities and were about to begin disassembling half the car. Many preferred to leave well enough alone, and with good reason.
Cheers and good luck
Old Aug 15, 2013 | 05:41 AM
alonco's Avatar
I was getting rattles from the front of my XK as I went over humps and bumps at slow speed. Looking at other posts in the forum I initially thought it was the bonnet / hood rattling.
The XK was going into the dealer anyway and i mentioned the noise and asked them to adjust the bonnet / hood fixing.
Dealer looked at it and diagnosed as suspension rattle, going back in on Monday for fuller investigation and possible replacement.
Will update after Monday.
PMKimpton
Aug 3, 2019 08:22 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
