Rear Window Sunshade/Cover fastener
Old Oct 27, 2014 | 03:43 PM
GrtShrk's Avatar
Default Rear Window Sunshade/Cover fastener
Looking for just one of these. PO broke one of the two that hold the rear window privacy cover in place. Tried Clipsandfasteners.com but was unable to locate. Does anyone have a part number or source. Trying to avoid paying big $$ at dealer.
Old Oct 27, 2014 | 04:26 PM
richzak's Avatar
Is there a part number molded into the fastener?
Old Oct 27, 2014 | 04:47 PM
GrtShrk's Avatar
Great idea Rich...its so darn small my old eyes missed the print the first time. Info molded reads exactly: >PA6< 2 southco
I would categorize the part as a "cam/compression latch" as the large handle piece folds 90 degrees to compress a rubber tube. Friction fits in the mounting holes in 2 of the 4 points around the Coupe's rear window. I'm doing a bunch of different searches now but with out much luck!
Old Oct 27, 2014 | 05:48 PM
WhiteXKR's Avatar
I think that is C2P19092. About $20 list at the dealer, $15 online here: Jaguar Parts - Direct JPLV Porsche Parts.com
Old Oct 27, 2014 | 06:04 PM
GrtShrk's Avatar
That is the part. Thank you!
I knew I wasn't the first to need one of these. I just didn't know the cover is called a "package tray." No way a package is fitting between the tray and glass....well unless it's a pizza!
Old Nov 11, 2014 | 07:23 PM
dougsjag's Avatar
This is exactly what you get when you order the above part number from that company. You do get the acorn nut and the rubber spacer. 2 for a little less than $50. The dealer wanted $70 each.
This is fantastic. I thought that it might not come with the nut and spacer, but it is all there. Thanks!!
Attached Thumbnails Rear Window Sunshade/Cover fastener-rear-window-cover-fasteners.jpg
Old Jul 7, 2020 | 10:04 AM
TraxtarXKR's Avatar
Just for anyone looking at this thread in the future... I lost the rubber grommet in the hatch, and had to buy replacement parts.
C2P24519 is another part number that works and is only ~$8-10 at the dealer.
https://parts.jaguarpalmbeach.com/p/.../C2P24519.html
For some reason, C2P19092 is the same part at almost 4x the price ($27)
https://parts.jaguarpalmbeach.com/p/.../C2P19092.html.
I can confirm this as I just received 2x
C2P24519 for $20 delivered to my door, but it would have cost $60 for 2x of C2P19092.
99xk8guy
Sep 29, 2025 10:51 PM
bamforp
Aug 14, 2024 05:36 PM
99xk8guy
May 28, 2024 09:36 PM
kevinl
Oct 31, 2019 06:15 PM
GordoCatCar
Jan 2, 2017 01:10 PM
