Recurring P0193 (fuel pressure high) on XK
Old Apr 29, 2019 | 11:00 AM
DGorvetzian's Avatar
Default Recurring P0193 (fuel pressure high) on XK
My wife's 2007 XK (147K) has a recurring P0193 code. My mechanic has already replaced the fuel rail pressure sensor, but the code is back. I saw posts indicating that pressure should be constant 55 psi. I was measuring 58 psi via OBDII while idling; I didn't check yet while driving. I did notice that, when I turned off the engine, the fuel pressure went up to 78 psi.
On other forums (X-Type, X100), I saw recommendations to change the fuel filter. That surprised me, as I presumed a blocked filter would cause low fuel pressure, not high.
Any thoughts on what could be going on here? I guess another faulty sensor could be the culprit, but I'm wondering if something else in in play.
Thx,
Doug
Old Jul 12, 2019 | 12:35 PM
gkubrak's Avatar
I'm looking into this also. I replaced my sensor due to a fuel leak (among other repairs I was doing at the time). Then the code started showing up. Someone was saying they replaced the fuel temp sensor and it went away but I find that hard to believe.
Vik976
Nov 6, 2019 07:59 AM
chow wah hoi
Apr 28, 2019 08:07 PM
1320racer
Aug 24, 2016 12:42 PM
Wahooesprit
Nov 2, 2015 01:53 PM
bgiff
Nov 4, 2014 07:49 AM
