Relays
Old Aug 3, 2025 | 07:48 AM
ChrisDak's Avatar
Default Relays
Relays...
I have In 06 XK Base. and for the life of me cannot find relay labels,numbers.
I'm trying to find the source of a .520 amp battery drain when the vehicle is supposed to be asleep and drawing less than .100 amp ..preferred 0.060 amp.
Any help appreciated.
I do know, for some reason. A relay in the engine compartment is on all the time. Even when pulling it it makes no difference to the current draw. More over , underneath the little plastic grill in the fuse panel , there is another relay ,nonserviceable, that is also on all the time.
If i can i identify these and the others i can maybe make some headway.
Given the fuse panel has sub circuit geometry, I'm guessing the engine compartment fuse panel ,is it self a module..not a "dumb" panel.
any help will be appreciated.
Serlock
Oct 12, 2017 09:24 AM
rtcosic
Jun 7, 2017 12:07 PM
Derek B
Oct 29, 2015 07:27 PM
kurtomatic
Sep 26, 2015 10:31 PM
NtAFord
Mar 8, 2013 05:57 PM
