Replacing the shift lever
Old Nov 7, 2016 | 03:51 PM
marvdenny's Avatar
Default Replacing the shift lever
On more than one occasion the shift lever has been moved ever so slightly but enough to put the transmission into manual mode; much to my surprise. This is an '07 XK so I was wondering if it is possible to replace the shift lever with the rotary *** that is on the newer models. Anyone know?
Thanks,
Marvin
Bakersfield, CA
Old Nov 7, 2016 | 04:46 PM
Tervuren's Avatar
The shift lever never puts it into manual mode, that is the paddles on the steering wheel.
Old Nov 7, 2016 | 04:56 PM
powerhouse's Avatar
Thanks,
Marvin
Bakersfield, CA
you must be hitting the paddles sometimes, this switches to manual, it will return to D mode when the car feels you've stopped using the paddles and the engine adjusts to the driving style, the car will only stay in manual/paddles if you have the lever in the S position
Old Nov 7, 2016 | 06:37 PM
Cee Jay's Avatar
What they ^^^^ said, but as far as swapping out the shifter for the knob, it'd be cheaper and easier to buy a 2010+ than to do all that. There is a TON of stuff that would need to be changed; software, firmware, hardware, transmission...... put aside three months and $15,000 if you want it done.
