Reset Sequence, First time blues.
Old Oct 18, 2025 | 04:16 PM
Circumnavigator's Avatar
Default Reset Sequence, First time blues - Ignore.
Was able to sort out the window reset as well as the convertible top reset.
All is good with the world.
Old Oct 18, 2025 | 04:38 PM
kj07xk's Avatar
AFAIK, just keep retrying the procedure.
I usually did it 2-3 times on each window.
If it’s not taking, and you do disconnect the battery again, touch the cables together to do a hard reset.
Old Oct 18, 2025 | 04:44 PM
Yes sir. I raised the top and started over.
Driver window. Passenger window. Top up - hold 60s. Top down - held 60s.
What I missed as letting go of the window switch then hold up/down again for 2s.
And that click is more of a mechanical noise, in the door.
When things aren't reset correctly, to make something useful and searchable out of this post:
Not only does lowering the top do the pause thing after unlatching and lifting a few inches.
BUT, also when raising the top, after the tonneau lid opens, you hear a motor running, but the top doesn't start moving for about the same amount of time as the pause when lowering.
Ironically, or not. That amount of time is about how long it takes for a window to open/close.
Like it is waiting....
Old Oct 19, 2025 | 04:00 PM
gmuirnz's Avatar
Drove home from pizza lunch with fellow Jaguar drivers and guess what the dreaded "HOOD NOT LATCHED" popped up. Oh well leave it parked up in garage while I go the SUPERCARS Gold Coast Races in Australia, will fix it when I get home!
David993S
May 19, 2024 10:45 AM
Mosin-Guy
Jan 7, 2024 12:20 PM
deltagroup
Sep 17, 2023 08:00 PM
drummr25
Aug 29, 2020 07:48 AM
kiphome
May 10, 2012 05:17 PM
