retrofit viper autostart/alarm to 2008 XKR
Old Nov 10, 2014 | 12:25 PM
hhv00586's Avatar
Default retrofit viper autostart/alarm to 2008 XKR
I really want to add an autostart feature to my car
Has anyone done this?
What bypass unit did you use?
Any advice?
The system I am trying to have installed is a Viper 5906v - which is an alarm and autostart system
Old Nov 10, 2014 | 03:55 PM
britannia's Avatar
MY advice "don't do it!" drove an F Type the other day; worst feature on the car IMHO!
Made me very anxious at each stop light! Having had 13 Jags I sometimes worry about starting first time; even my 2007 XK !
Being 80 I do worry more about starting, anything!!! Just installed a new Kitchen Faucet only took a day! it said 45 mind on box; they lied...............
Good luck, Adrian
Cheers, Adrian
Old Nov 11, 2014 | 05:00 PM
Ngarara's Avatar
Adrian's referring to the stop-start system used on many modern cars to reduce fuel consumption. What you have is a remote-start system.
I suspect it would be impossible to fit to the XKR, unless you were prepared to keep a key fob permanently docked in the car. The security system has a conversation with the fob and verifies that it's valid before the car will start. Even then, I'd guess you'd have to somehow wire the Viper into the Start switch.
AzzaXKR
Sep 27, 2015 07:25 AM
Rostman
Sep 18, 2015 02:59 PM
hhv00586
Sep 18, 2015 08:59 AM
handcuffsready
Sep 7, 2015 03:16 AM
dcvickers
Sep 2, 2015 06:14 PM
