Reversing Light
Old Feb 6, 2022 | 04:33 AM
Spitjag's Avatar
Default Reversing Light
Hi and Apologies if this has been mentioned before. My 2006 Uk spec has no reversing light and after a little online searching it appears its an LED assembly that needs to be replaced as a unit. Is this the case or has some clever member found a way of repairing it?
Many Thanks
Ian
Old Feb 6, 2022 | 08:25 AM
kj07xk's Avatar
Just to clarify, you don’t have a ‘reversing light’ on the passenger side of your car?
(As there would not be one on the driver’s side, only the rear fog light on that side. A fog light on the driver’s side and a reversing light on the passenger side is the normal setup for your car.)
Old Feb 6, 2022 | 10:28 AM
Spitjag's Avatar
Hi ,Yes I am aware there is only one reversing light on my model and the right hand assembly (Uk driver side) is a fog light. Looking at the internet it appears the whole unit needs to be replaced at about £200... Gosh!
Old Feb 6, 2022 | 11:55 AM
kj07xk's Avatar
Ouch. Keep an eye on the UK eBay, maybe a used one will show up at a better price.
Old Feb 7, 2022 | 01:28 AM
gkubrak's Avatar
I just put in LEDs in the reverse light and the fog light. But for some reason they just blink whenever I engage them. Still working it out...
Old Feb 7, 2022 | 11:32 AM
kj07xk's Avatar
Your lights are blinking due to FET transistor overload. See this thread where George Kale figured it out for the 5.0L to 4.2L tail light swap:
https://www.jaguarforums.com/forum/x...s-36907/page3/
In post #51 he has a PDF file that has the parts he used for the conversion. I suspect that you will also need to add the relays to get the backup and fog lights to work in your case.
Petz
Aug 3, 2021 03:11 PM
Muddybear
Jun 14, 2020 12:58 PM
Ingo
Oct 15, 2013 01:12 PM
jhxj6
Apr 22, 2010 11:03 PM
jvegas
Feb 2, 2008 05:16 PM
