Right side A/C not working
Old May 11, 2018 | 04:24 PM
Macc's Avatar
My air conditioning is all mixed up after winter. Driver side does get lukewarm air when passenger gets hotter - but no way cold air. If I turn "auto" on, temperatures get even hotter...
Damn. Have to go and get some service. Hopefully not everything is blown up.
Old May 11, 2018 | 05:18 PM
davchr's Avatar
You need to start with the basics.
1. Does the compressor run? No, probably way low on freon and the low pressure switch is opening. Or could be a blown fuse. Need to sort that out to get the compressor running.
2. If compressor is running you need to see if it is running properly and has an adequate freon charge. To do that you need a set of manifold gauges to look at the suction and discharge pressures or a code reader that will give you HVAC diagnostic codes. That information is necessary to do any real troubleshooting. Anything else would be a wild guess. (Low on freon would be my first wild guess.)
johnro6659
Nov 21, 2020 01:14 PM
Porterfamily
Jul 31, 2017 05:39 PM
ragman1171
Sep 26, 2014 09:23 PM
milleniumaire
Apr 24, 2012 06:14 AM
Xtype'02
Apr 23, 2010 06:13 AM
