Rr Caliper Pistons Won't Turn In
Old May 6, 2019 | 03:26 PM
viper1996's Avatar
Default Rr Caliper Pistons Won't Turn In
Got about one turn on them and that's it. Bending caliper tool handle they will not budge. E brake at its off detent with spring removed...Even opened the bleeder...Ideas? Ready to put the old half worn pads on and call it a day...
Old May 6, 2019 | 03:51 PM
110reef's Avatar
Are you turning the piston as well as pushing the piston?
Old May 6, 2019 | 05:33 PM
viper1996's Avatar
Enough to bend the handle!!!
Old May 6, 2019 | 07:55 PM
jagtoes's Avatar
Time to pull the caliper and see what's going on. Is there any rust in the area. Did you try turning it the opposite way . sounds like you either need to soak it in penetrating oil or get it rebuilt or replace it.
Old May 7, 2019 | 07:20 AM
110reef's Avatar
Originally Posted by jagtoes
Did you try turning it the opposite way.
This^^
I think they turn only one way. I have a left handed turn and a right handed turn in my kit.
Old May 9, 2019 | 02:25 PM
Tiretrauma's Avatar
Pull the caliper off and see if you can turn it on the bench on a vice. Might be time for a new caliper. I’d also flush your brake fluid regardless of outcome.
iownme
Apr 30, 2020 01:34 PM
Mudman
Dec 27, 2013 04:16 AM
avt007
Dec 19, 2013 02:40 PM
thuffner3
Feb 2, 2012 05:53 AM
tsingtao35
Aug 25, 2011 04:56 PM
