Satellite connector question
Old Mar 7, 2017 | 11:59 AM
synperkaya's Avatar
Default Satellite connector question
Okay, been having problems with my XK not acquiring a Satellite signal, my code reader says its the antenna, and I have already replaced the antenna..now I am thinking its the cable from the antenna to the receiver..but I dont know what the grey connector on the Sat receiver is called..I would like to get an extension cable to see if the cable is the problem..any help would be appreciated.
Thank you
Old Mar 7, 2017 | 11:34 PM
ralphwg's Avatar
There have been other people with the same type of problem. At the top of the page on the right hand side is a search box. Type in a phrase such as not acquiring satellite signal and see what you pull up. Good hunting. It also helps to identify your xk by year, model, etc.
Old Mar 8, 2017 | 09:05 AM
synperkaya's Avatar
Thank you Ralph...and your are correct about the search tab..Trust me I did multiple searches on this site, other sites,, ebay to see the various connectors sold..My problem on my 2007 XK is that I just want to run a jumper from the module to the sat antenna to see if its the cable or the replacement antenna..
thanks again for the help
al
