Scan code
Old Apr 22, 2018 | 08:15 PM
Pash's Avatar
Default Scan code
I have a 2007 XK with 30,500miles. Scan code P0128 came on after 6 month of storage. How serious should I be with this code?
Old Apr 23, 2018 | 02:34 AM
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to X150 forum. The Feedback & Suggestion Centre is for posts about the forum and not for technical questions. This is the place to post technical questions about your model.
You should be serious about anything which suggests an issue with the cooling on a Jaguar V8.
During any prolonged period of storage, the battery should be maintained on a tender. You should ensure the battery is in good condition and fully charged to eliminate the possibility this is a spurious error code resulting from low voltage. Also consider is there the possibility of small animals nibbling at the wiring during storage? In some locations this is a real risk and considerable dame has been reported in several of our model forums.
If these precautions have been observed and it is a genuine code, here are the possible causes of P0128 - coolant temperature below thermostat regulating temperature:
The first action should be to check the coolant is up to level and top up if necessary. After this I would clear the code, run the vehicle suffciently for warm up and see if the code resets. If it doesn't, you can stop worrying. If it does, then the next likely culprit is a sticking thermostat.
If both coolant level and thermostat operation are correct, then it is on to cooling fan circuit. A fault here should set additional error codes.
Old Apr 23, 2018 | 05:32 AM
kj07xk's Avatar
Follow Graham’s advise.
Most likely you’ll find that the thermostat is stuck open. Due to a poor design, the gasket stretches and blocks the thermostat from fully closing, this prevents the engine from warming up as quickly as the computer thinks it should, resulting in the code being thrown.
Not as serious as a stuck closed thermostat and having the engine overheat, but you’ll still want to fix it. It’s the first repair I did on my 07 XK. You should replace both the thermostat and the plastic housing at the same time. If you’re doing it yourself, there is a thread here that has a nice step by step, which you can use along with the steps in the service manual. You can find the parts (thermostat plus housing) online as a complete package, and IIRC it was around $130.
Old Apr 23, 2018 | 06:43 AM
winstonsalemncxk's Avatar
I second the comments above. I had the same code due to my thermostat being stuck open. kj07xk is absolutely right that if you replace the thermostat you need to go ahead and replace the plastic housing at the same time. Good luck!
Peter
Lucadelta
Apr 10, 2017 04:59 AM
Bobcameron
Oct 16, 2016 09:51 PM
JB73
Oct 2, 2016 05:22 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
Artie Ziff
Aug 28, 2007 09:25 PM
