Scratched the convertible itch
Old Dec 5, 2023 | 12:52 PM
rowlands's Avatar
Default Scratched the convertible itch
To cut a boring story short - I traded in my coupe and got an XK convertible, and upsized to an XKR while I was at it (with performance active exhaust and the Portfolio Package aka 'Special Edition' in the UK/). 2013 with 59,000 miles.
I bought it from Carvana (I know, I know...), The positive from that is that I had a week to get it checked out, and I could always return it for free.
So I took it to Jaguar Nashville the day after it was delivered. If there was nothing fatally wrong with it and Carvana pays for any repairs I'd keep it, if they didn't, I'd return it and keep looking.
The Jaguar service rep came down and set next to me like a doctor coming to break bad news, armed with half a tree's worth of paper in his hand. Anyway, whilst there was a lot that needed attention, none of it, if fixed, rose to the level of 'return the car NOW'. And Carvana did agree to pay for it all after sending a 3rd party inspector out to confirm the issues, so there we go.
Now, I know I've taken a plunge with a car that had clearly not been looked after well by the previous owner (there was some good service history up to the prior owner who had the car for 3 years) as even the briefest lookover by a JLR technician would have picked up some of theses issues. Or maybe they knew of them but didn't want to take care of them. Either way, I am aware this is not a 'one old lady owner always serviced at correct intervals' kinda car, but if it doesn't work out, it doesn't and I'll move on - not a big deal.
Main reason for posting was to share what came out of the Pre Purchase Inspection report so you can ogle at current JLR service center parts and labor cost prices and maybe use as reference for parts needed for various tasks, and also to those who had never considered Carvana before - hey, I've heard horror stories like everyone else, but if they'll cover OEM parts and JLR technician work up to at least $12k on a jag you buy from there to bring it up to speed, don't dismiss it out of hand.
WARNING LIGHT
Concern
REPLACE SUPERCHARGER WASTEGATE HOSES , BOTH ARE SPLIT AND LEAKING VACUUM.
Correction
REPLACED BOTH SUPERCHARGER WASTEGATE HOSES.
2 x AJ811964 - HOSE = $91.40
1 hr Labor = $179
Total inc tax/fees = $316.40
ENGINE
Concern
REPLACE VACUUM PUMP AND RESEAL LOWER OIL PAN . BOTH ARE LEAKING OIL .
Correction
REPLACED VACUUM PUMP AND RESEALED LOWER OIL PAN.
1 x AJ813786 - PUMP-VACUUM = $741.20
2 x C2Z30121 - SCREW = $13.36
1 x AJ813202 - PLUG-OIL DRAIN = $14.86
8 x 0-20 CAS EDGE PRO 0W = $110.40
4hr Labor = $716.00
Total inc tax/fees = $1795.31
BRAKE SYSTEM
Concern
REPLACE RIGHT REAR BRAKE WEAR SENSOR , SENSOR HAS BEEN CUT AND BUT CONNECTOR HAS BEEN INSTALLED OVER THE WIRES.
Correction
REPLACED RIGHT REAR BRAKE WEAR SENSOR.
1 x C2D2976 - SENSOR BRAKE PA = $102.18
1.5 Hrs Labor = $268.50
Total inc tax/fees = $436.28
BRAKE SYSTEM
Concern
REMOVE LEFT FRONT WHEEL SPEED SENSOR, RE INSTALL TO HUB, AND RETEST FOR POSSIBLE REPLACEMENT. C0031-31 LF WHEEL SPEED SENSOR NO SIGNAL STORED IN ABS MODULE ,SENSOR MOUNTING CLIP IS INCORRECTLY INSTALLED TO HUB
Correction
REMOVED AND REINSTALLED LF WHEEL SPEED SENSOR. VERIFIED CORRECT OPERATION.
0.5 Hrs Labor = $89.50
Total inc taxes/fees = $108.04
COOLING SYSTEM
Concern
REPLACE REAR COOLANT CROSSOVER , WATER PUMP , THERMOSTAT. REAR CROSSOVER LEAKING , WATER PUMP BEARINGS HAVE FREEPLAY , THERMOSTAT HAS COOLANT TRACING FROM SEEM INDICATING LEAK IS STARTING TO FORM.
Correction
REPLACED WATER PUMP , THERMOSTAT , AND REAR CROSSOVER . VACUUM BLED COOLING SYSTEM . VERIFIED CORRECT OPERATION OF COOLING SYSTEM.
1 x C2Z28258 - TUBE = $76.76
1 x C2Z86930 - HOSE = $69.56
1 x C2Z19929 - THERMOSTAT = $131.27
1 x AJ813909 - PUMP-WATER = $346.68
1 x AJ811539 - SEAL = $12.80
1 x C2Z18658 - TUBE = $42.67
1 x AJ814056 - PIPE-HEATER = $184.36
1 x T2H59153 - ANTIFREEZE = $150.80
9 Hrs Labor = $1611.00
Total inc taxes/fees = $2925.82
FRONT SUSPENSION
Concern
REPLACE FRONT LOWER FORWARD CONTROL ARMS , BUSHINGS HAVE SPLIT AND HAVE LEAKED ALL OF THEIR FLUID OUT , REAR MOUNTING POINTS HAVE LIGHT FREEPLAY
Correction
REPLACED FRONT LOWER FORWARD CONTROL ARMS.
2 x C2P17092 - ARM-WISHBONE = $2390.72
2 x C2P7440 - NUT = $15.04
2 x C2C23854 - CAM = $13.96
2 x C2P7437 - BOLT-SPECIAL = $45.76
3 Hrs Labor = $537.00
Total inc taxes/fees = $3339.12
REAR SUSPENSION
Concern
REPLACE REAR LOWER CONTROL ARMS , TOE LINKS , AND REAR SWAYBAR LINKS . ALL BOOTS ON LISTED PARTS ARE TORN AND LEAKING GREASE.
Correction
REPLACED REAR LOWER CONTROL ARMS , REPLACED REAR TOE LINKS , REPLACED REAR SWAY BAR LINKS .
1 x C2P16878 - ARM-WISHBONE = $551.90
1 x C2P16879 - ARM-WISHBONE = $551.90
2 x C2D51044 - LINK-STABILISING = $473.06
1 x C2D49528 - LINK-ANTI ROLL = $147.69
1 x C2D49529 - LINK-ANTI ROLL = $147.69
6 Hrs Labor = $1074.00
Total inc taxes/fees = $3277.39
ALIGNMENT
Concern
ALIGNMENT AFTER CONTROL ARM REPLACEMENT.
Correction
PERFORMED ALIGNMENT
2 Hrs Labor = $159.00
Total inc taxes/fees = $191.95
Overall Total: $12,390.31
And here's the beast, full of new parts.
Old Dec 5, 2023 | 12:59 PM
Cee Jay's Avatar
Hey, it's ten years old. Time to do those things anyway. Now you have a nearly new 2013!
That seems like a great deal to me!
Old Dec 5, 2023 | 01:10 PM
rowlands's Avatar
Yeah, that's how I'm looking at it. When he showed me the list of items required it was like a greatest hits collection of 'things to do on the XK circa 60k miles', so why not.
And the first time I put the top down and went for a drive I knew I'd made the right choice.
And as a clarification, I did pay a $350 deductible towards the cost as I wanted the work done at a JLR service center instead of the 'in-network' shops that Silver Rock (Carvana warranty company) wants you to use. Money well spent as SR would probably have asked a local Firestone's teenage wrench monkeys to have a go at it. The Jag shop were good about it, they made sure they had a tech with familiarity with these cars on hand to do the work.
Old Dec 5, 2023 | 03:05 PM
Canadacat's Avatar
Cool now time to add the Jagwrangler remote convertible top control option.
Old Dec 5, 2023 | 03:19 PM
Cee Jay's Avatar
DEFINITELY That!
Old Dec 5, 2023 | 04:08 PM
kj07xk's Avatar
Wow. They foot the $12k bill, nice. Nothing comes for free, so you maybe you overpaid to start with? But you were satisfied with the price to pull the trigger, so it’s water under the bridge, and you’re a happy camper. Enjoy the ride, and yeah, get the remote top controller! Best mod you’ll make to your car.
Old Dec 5, 2023 | 04:18 PM
Tiepolo's Avatar
Never heard about a carvana kind of thing in EU but it appears interesting.
You know have a great looking car almost as new.
But, To have the full info, and understand if that's a "bang for the buck", how much did you finally pay for it?
I mean, by the end after the work was done.
Thanks.
Old Dec 5, 2023 | 04:35 PM
rowlands's Avatar
It already had it! I was leafing through the folder in the glovebox and found the documentation for it. Tested it and it works.
Confused the service center - they told me there may be a problem with the top as it appeared to open on it's own when they went to bring the car round front. I explained the aftermarket mod and that the kid must have been trigger happy with the smart key when approaching the car.
It was on my list of things to get, so super happy that it was already installed.
Old Dec 5, 2023 | 04:37 PM
rowlands's Avatar
Thanks.
I paid $31,000. I don't think that's too extravagant. I was baking into it that there were going to be repairs needed and I wasn't going to be paying for them (unless very minor).
EDIT - that was the sale price, I traded my 2014 XK in, so net spend was a lot less.
Old Dec 5, 2023 | 06:13 PM
Tiepolo's Avatar
WoW That's a bargain to a European!
Over here you can't get such mileage and year model for less than 55000$
You should feel really happy. She's beautifull.
Old Dec 5, 2023 | 09:53 PM
McJag222's Avatar
I need to update me spectacles - I thought you'd scratched the bitch....
Old Dec 7, 2023 | 09:18 AM
rowlands's Avatar
Just to add - Carvana/Silver Rock are also covering the purchase of 2 new OEM Orona front wheels at $1700 each as the inspection report noted the originals were bent. They were sent to a wheel repair shop who stated they were irreparable due to the location of the bend. They also coughed up money towards the cost of refinishing all 4 wheels in the original polished alloy finish (last owner had them painted black). I owe the service rep at Jaguar Nashville a drink or two, he's worked wonders on that.
Old Dec 8, 2023 | 07:31 AM
GMEaton's Avatar
Wow - I am putting you in charge of buying my next used car. Well done!
Old Dec 8, 2023 | 03:57 PM
Tiepolo's Avatar
I want Carvana in France!!!!
Where do I sign the petition?
Old Dec 9, 2023 | 10:11 PM
ralphwg's Avatar
That is a black brother or sister to my 2013 XKR Rhodium Silver Ser Nr 49488 (last 5 digits). You are really going to enjoy it. So all in about $44k Not bad! Congratulations.
Old Dec 10, 2023 | 07:09 AM
wymjym's Avatar
Just, wow!
To be clear. Carvana sold you a car for 31k and then paid a service center over 14k to correct everything on the repair report?
just noticed that the alignment labor was charged at much lower rate, why?
Finally, a relative of mine had a car brought in to purchase (carvana in austin tx) it needed brake rotors. They had their service center check them and stated they were fine. The rotors were below the accepted thickness but the car did still stop. Carvana would not budge on having Jag/Austin repair the brakes. The car was not purchased.
Such a different story you tell.
wj
Old Dec 11, 2023 | 02:15 PM
rowlands's Avatar
Originally Posted by wymjym
Just, wow!
wj
Yes.
Well, not EVERYTHING, as the report had a couple of recommended maintenance items on it (brake fluid flush for example) that they would not cover, but they covered everything mechanical/covered by the 90 day warranty you get. It was never expected they would cover normal recommended maintenance.
Carvana will generally do everything to not have you return the vehicle. The 7 day return window gives you a lot of leverage whilst you're still in it. I was more surprised that they agreed to extend that 7 days to 14 days to allow Silver Rock time to approve or deny the warranty claim. I made it clear that I would return the car if the warranty claim was denied, or if I did not know the answer to the claim decision before the return window closed (hence asking for an extension that they granted).
Not sure why the alignment labor rate was lower. Maybe that's considered a lower grade technical task than others. As I was only paying the $350 deductible towards the work, I wasn't too fussed about those details.
I'm sure others have had frustrating experiences purchasing from Carvana, I can only relay my - so far - positive one. I've also read horror stories: borderline deathtrap cars that customers returned as there was critical damage, only to find Carvana listing it again immediately for someone else to buy (and I assume, hopefully someone not so diligent in getting it inspected...), stolen cars etc.
Old Dec 16, 2023 | 07:09 PM
XKDreams's Avatar
I’m a newcomer and curious. Is that typical service to expect on a 60,000 mile XK?
Old Dec 18, 2023 | 02:27 PM
rowlands's Avatar
I'd say control arms, and elements of the cooling system, such as water pump and some coolant hoses are common items that come up around this mileage if not before, but each case is different.
The costs listed here are extreme of course as these are OEM parts purchased through, and installed by a JLR service center. Going to an indy will bring the prices down, and DIY endeavours more so. I'm taking advantage of a warranty here.
The Mekon
Dec 27, 2022 12:52 PM
Unhingd
Feb 26, 2019 12:01 AM
Translator
Detailing / Car care
372
Feb 26, 2014 06:51 PM
muckbury
Nov 3, 2013 09:20 AM
