SDD
Old Mar 31, 2021 | 01:29 PM
pauledddy's Avatar
Default SDD
Evening All,
Using SDD I'm trying o edit the CCF and when i click it, i get this pop up. Any ideas?
Thanks in advanced!
Old Mar 31, 2021 | 01:38 PM
AlexJag's Avatar
Sponsor
Originally Posted by pauledddy
Evening All,
Thanks in advanced!
What what are you trying to do?
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Mar 31, 2021 | 01:51 PM
tmich's Avatar
Sorry for hijacking this topic. I used to use a CCF editor without any problems. Now when I have a "golden key" screen (VIN + random token + blank for a code) - when I provide a code from Vehcom pop up disappears and it goes back to a main page of a session (CCF editor access is closed) and I need to start golden key access once again (and result will be the same - vin, token, code and window closes).
Any ideas?
SDD 159 - version "enhanced"
Old Mar 31, 2021 | 03:41 PM
Sean W's Avatar
The VDF and SPA files have to be downloaded directly from JLR on SDD versions > 150. The files are not installed in your version pauleddy.
Old Mar 31, 2021 | 06:05 PM
pauledddy's Avatar
I fixed it by simply enabling the network and it worked. Didn't know I had turned it off! 😂
Old Mar 31, 2021 | 06:12 PM
Cee Jay's Avatar
Yeah, that big red box with the X where the INTERNET CONNECTION is located. I don't use that version so I don't need to connect. I always see red.
I also notice your battery indicator is yellow...... do you have the correct power supply hooked to your battery??? It'd really suck to have your battery die when you're messing with the CCF...
frankc
General Tech Help
Oct 25, 2024 04:53 AM
pauledddy
Oct 12, 2022 11:03 AM
Aarcuda
Apr 3, 2020 02:59 PM
Sean W
Apr 6, 2018 09:17 AM
fingers
General Tech Help
Nov 21, 2015 09:43 AM
