Secondary AIR pump Vacuum code (P2431)
Old Apr 28, 2017 | 12:55 AM
Geosnooker2000's Avatar
Default Secondary AIR pump Vacuum code (P2431)
Has ANYONE here had this code, and if so, what was your repair experience? I'm going to do some detective work this weekend with some smoke, but would like some stories about others to give me a place to start looking for the leak. I hope it's not the actual AIR pump. That dude is over $400.
Old Apr 28, 2017 | 06:34 AM
JagV8's Avatar
Looks exceedingly rare (across all the models). The code apparently relates to a sensor reporting out of range.
Old Sep 20, 2017 | 09:25 AM
Bump for hopefully somebody who has dealt with this before. I would love to grab a ohm meter and start probing but I have no idea what to do. I don't need to drop $1000 on a repair that is not affecting the car at all as far as I can tell. I can still get 28-30MPG out of this thing if I try hard enough, and it will still snap your neck when you stomp on the right vertical pedal, so the engine seems to be running fine. And all I have ever experienced is that vacuum issues kill engine performance.
Please someone help if you can.
Old Sep 20, 2017 | 11:24 AM
captusnr's Avatar
Default A.i.r. Pump replacement
I had the same code and it was determined that the Secondary Air Pump was defective and had to be replaced along with a valve. The pump costs in excess of $550 dollars and involves more than 3 hours of labor time to replace as the front bumper must be removed. In addition to the P code the Pump was making a very loud screeching noise upon the first start-up in the morning. Total repair cost by dealer $1,300.
Old Sep 20, 2017 | 01:29 PM
And that's kinda my point. Mine does not make any screeching sounds, and everything seems normal. So I am reluctant to just start throwing parts at it. I am suspicious that there is a short or a sensor that is out of range.
Old Jul 7, 2021 | 05:25 PM
pk4144's Avatar
Found this thread on a search, as I was told my vacuum pump needed to be replaced.
True confession: I wasn't really aware what a vacuum pump did.
My dealer's service dept are good folks and knowledgeable, and the car is 11 years old and just shy of the 100,000 mile mark, so I believe them. Yet like you, the car seems to be running fine.
This will be covered under my warranty so it's a free repair/replace for me. When I get the car back I'll ask, and post a photo of that page to let you know repair description and what they bill as parts/labor.
Old Jul 7, 2021 | 05:48 PM
captusnr's Avatar
Default Same experience
First loud screeching noise followed by Secondary Air Pump replacement. Major financial expense
