Seeking advice on buying used XK
Old Jan 1, 2015 | 09:20 AM
Lukeeeee's Avatar
Default Seeking advice on buying used XK
Greetings. New member here, entertaining buying a 2007 XK vert.
(1) Any problems in particular to look for and (2) does high mileage...90K, concern anyone.
TIA
Russ
Old Jan 1, 2015 | 09:27 AM
gatekeeper's Avatar
If car was in Florida all it's life, rust shouldn't be a big problem. Except maybe from sea salt. Mileage if correct is not high for a 7+ year old vehicle. Drive it, make sure everything works as it should, no check engine lights on. get a Carfax if you can.
Old Jan 1, 2015 | 09:40 AM
WhiteXKR's Avatar
TIA
Russ
These cars can handle the mileage, but remember there are many low mileage examples out there of the convertibles, which often are lightly driven.
Looks for the following problem areas:
-Rear window detaching from fabric top
-Top of leather dashboard delaminating
-Water in the passenger footwell from clogged A/C drain
In addition to wear items like tires and brakes that may need to be attended to, plan on a new battery and a preventative replacement of the plastic thermostat housing and pipe. A test drive will tell you whether the suspension needs any attention.
Old Jan 1, 2015 | 01:27 PM
axr6's Avatar
For these cars, there are many low mileage examples available. Higher mileages should result in very attractive sales prices.
If you can get that great deal on the car do invest in a thorough mechanical check as the repairs on them tend to be rather expensive. I have had 5 late model Jags in the row with absolutely minimum issues. But, all of them had low mileages.
Old Jan 1, 2015 | 03:25 PM
powerhouse's Avatar
Lukeeeee, i have a 2007 xkr and love it. Had the old xk8 for 6 years then traded for the xkr. Have it nearly a year now and apart from small minor issues ,i wouldn't part with it, if it is a good deal and mechanically sound, you'll love it.
Just a few pics of mine,
I have a post up called,
Some Exhaust noises you might like, if you would like to view, my car can be seen in the videos, nice noise.
Attached Thumbnails Seeking advice on buying used XK-cannonball-4.jpg   Seeking advice on buying used XK-pamerstown3.jpg   Seeking advice on buying used XK-nice-arse.jpg   Seeking advice on buying used XK-dsc_0066.jpg   Seeking advice on buying used XK-dsc_0081.jpg
Old Jan 4, 2015 | 10:40 AM
mosesbotbol's Avatar
$2-2.5K will take care of all preventive services that care may need and should be considered on the onset of your purchase. Engine will go for as long as you want to own it. I've seen them with 200K and no rebuild.
Goncalo Proenca
Sep 28, 2015 01:26 PM
simongulliver
Sep 16, 2015 03:40 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
Ipc838
Sep 13, 2015 03:27 PM
