self leveling headlights
Old Jul 3, 2011 | 03:53 PM
pbcs004's Avatar
Default self leveling headlights
when the car is started the left headlight goes through the motion of dipping down and self leveling the right headlight does not. I believe the right heqadlight was replaced in a previous accident. Is it possible that the headlight was not a self leveling light and that is why it does not dip at start up. How can one tell what kind of light it is?
Old Jul 4, 2011 | 07:19 AM
TomServo's Avatar
I discovered the exact same problem with the pre-owned 08 I bought the first time I drove it at night. Local Jaguar dealer had to order and replace the entire headlight assembly.
Man I hope this was a one time anomaly as my factory warranty expires in Nov and I discovered the on-line cost of the assembly was $1300 w/o labor
http://www.gaudinjaguarparts.com/par...layCatalogid=0
Do extended warranties cover something like this?
Good luck
Tom
Old Jul 5, 2011 | 02:23 AM
Jag-Mad-Kiwi's Avatar
What you could do LADA if you don't won't to replace the $1300.00 light,is get your your machanic to rig up a piece of string from your left foot big toe to you light,cost would be ferry ride,tank of gass,string and a box of bear!
Old Jul 18, 2011 | 11:13 PM
07XKJaguar's Avatar
I noticed after reading this that mine no longer do the self check leveling when you first turn them on. My garage is level so I don't know if that has anything to do with it or not. I'll have to do some checking
Old Jul 19, 2011 | 07:41 AM
Brutal's Avatar
when replacing headlight assemblies, many times they have to be programmed with ids/sdd by the dealer to auto level. Ide lay moeny the body shop didnt know this and just stuck it in. file a supplement to your original claim and take to the dealer to fix and be reimbused
Old Jul 20, 2011 | 07:44 PM
07XKJaguar's Avatar
I replaced my right headlight due to it being damaged from a previous accident. It was replaced with a used one in great condition. It auto levels without being programmed. I went out last night and mine do not auto level when in my garage. So I back the car out some so that it sat on an incline and turned them on. They auto leved. So I guess if the area is already level I don't notice it doing the auto self check thing.
Old Jul 20, 2011 | 10:26 PM
Brutal's Avatar
No theyre supposed to drop down and come up when you start the car with the lights on. except for the newer adaptive cornering XK headlights. They go down, come up, goes crosseyed and then corrects Not all new lights have to be programmed, only if they do not auto check when you star the car with lights on. And it can be only 1 light or both that fail to self check
Old Aug 25, 2011 | 02:07 PM
Chaos236's Avatar
How do you know if you have them? I have the adaptive cruise control.
Old Aug 26, 2011 | 04:18 PM
07XKJaguar's Avatar
I believe the adaptive cruise and headlights were a package together.
Old Aug 26, 2011 | 05:53 PM
Chaos236's Avatar
Thanks,I have them,seem to have all three goodie packages.
Old Dec 11, 2021 | 10:14 AM
Deabs's Avatar
My 2009 XKR has leveling headlights but not adaptive cruise control. My low beam headlights do the self check on startup. They dip down then come back up. I haven't noticed them move horizontally on start up but they point left or right in response to turning steering wheel. I thought it had cornering lights when turn signal was activated until I observed the lights moving without turn signal activation.
My car was 12 years old when I bought it and the headlights were badly out of adjustment. The left side was very low and right side a little high. Right side needed directed further right also. So...my question is what activates the self leveling feature to adjust the headlights up/down while driving??
New to Jaguar Forums...this is my first post!
Old Dec 13, 2021 | 11:04 AM
Deabs's Avatar
Default Adaptive Front lighting System (AFS)
Okay so I'm a little wiser now. My car has the AFS which is demonstrated by the swiveling projector lamp in headlight assembly as well as the cornering lamps. Below from service manual:
"Two levels of headlamp are available; Bi-xenon or Bi-xenon with Adaptive Front lighting System (AFS). The AFS headlamp has a swiveling projector module which moves the headlamp beam in the direction of travel. The AFS headlamp also features a cornering/static bending lamp which illuminates the area at the side of the vehicle when turning into driveways for example."
Old Dec 14, 2021 | 03:08 PM
Barry Leftwich's Avatar
i remember my 2007 XKR would do it on start up where the head lights look down and look back up and it would look so cool.The newer models like my 2013 don't do it and you'll notice they just move around slightly and it's barely noticeable unless it's an adjustment switch i don't know about to turn the feature on
Old Nov 22, 2024 | 01:39 PM
JagXKR2009's Avatar
Default 2009 XKR (X150) Self Leveling headlights
I have the Coupe since new and the dipping problem has happened twice. I did have one dead bulb and my NY dealer wanted 2,800 USD to replace the entire assembly. The dipping problem was fixed both times by replacing the ballast screwed under the headlight. OEM part is about $70.00, but a perfectly fine after market can be had on Prime for half that. I have 132,000 miles on the car and it is a daily driver!
dhog4n
Apr 15, 2020 02:48 PM
RonK
Jun 11, 2017 05:58 PM
spanky145
Jan 18, 2014 04:13 PM
bklynchris
Apr 21, 2013 11:43 PM
lexoman
May 3, 2011 10:01 AM
