Shocks struts part # crossover fitment list
Old Apr 27, 2024 | 04:19 PM
trkyam's Avatar
Default Shocks struts part # crossover fitment list
Looking to find find and organize part numbers for
our XKs, as this information seems mysterious
and hard to find factual answers on what will fit.
4.2 XK with CATS front:
4.2 XK with CATS rear:
5.0 XK with CATS front:
5.0 XK with CATS rear:
4.2 XK without CATS front:
4.2 XK without CATS rear:
5.0 XK without CATS front:
5.0 XK without CATS rear:
XJ shocks crossover fitment?
XF shocks crossover fitment?
F-type shocks crossover fitment?
Old Apr 27, 2024 | 05:17 PM
xalty's Avatar
all aluminum cars have the same top mounts and bolt pattern
the dew98 steel cars have a different type of top mount
Old Apr 27, 2024 | 06:47 PM
trkyam's Avatar
Yes, top shock mounts for XJ and XK front and back are shared. Howbabout the shocks themselves?
Old Apr 27, 2024 | 08:43 PM
kj07xk's Avatar
Wasn’t aware you could get a 5.0 without CATS.
Old Apr 27, 2024 | 09:44 PM
kj07xk's Avatar
Back when I had an office, I had some sticky notes with results of my research into those part numbers, have to see if I can find them.
IIRC, the 2010-2011 5.0 cars had different part numbers than the 2012+ models. Now that could be just because there was a supplier change when going to the face lift, don’t know.
For completeness, may want to include the XKR and XKRS in the table.
Old Apr 28, 2024 | 04:49 AM
guy's Avatar
guy
I think if you use the search feature in this forum, you will find the answers you are looking for. If memory serves me correctly, this has been discussed a few times...
Good luck.
Cheers.
Old Apr 28, 2024 | 04:57 AM
trkyam's Avatar
On the contrary I found a bunch of confused people
unsure of what will actually fit
Old Apr 28, 2024 | 06:06 AM
guy's Avatar
guy
:-). well, the trials and tribulations of using a forum as an authoritative source of information.
And to be fair, “someone” will need to do the experimentation if a deviation from spec is preferred. And it won’t be me as I’m happy with oem and spec.
Additionally, this is the better managed forum of those I use. I’m very happy with quick references in the stickies.
Using the terminology from the workshop manual I’ve found that the cross referencing part numbers from a variety of factory parts sources are easily sourced.. if sticking to spec. Otherwise, get a cup of tea and start comparing the specs of the numerous parts…. I’m not so energetic.
Old Apr 29, 2024 | 02:42 PM
trkyam's Avatar
For some reason i'm unable to edit my original post:
5.0 XK with CATS front: C2P17670 (jag part #)
5.0 XK with CATS rear: C2P17674 (Jag part #)
Old Apr 29, 2024 | 03:13 PM
bydand's Avatar
You mean this?
xk
https://parts.jaguarlandroverclassic.../brand/jaguar/
xf
xj
f
For any other's just change the ID (id) code to the model code required.
Old Apr 29, 2024 | 04:43 PM
trkyam's Avatar
wow, there is a lot of part numbers for shocks which may be identical..
panthera999
Jan 19, 2024 04:55 AM
Dymaxxion
Apr 27, 2023 10:50 AM
panthera999
Feb 28, 2022 08:51 PM
Dean Brennan
Oct 15, 2020 12:14 PM
trkyam
May 1, 2018 05:35 AM
