Should oil change only be done by dealer?
Old Apr 7, 2022 | 11:10 AM
  #41
80sRule's Avatar
Originally Posted by Cee Jay
Okay then for temperature range, but is that AMBIENT temperature, or ENGINE temperatures??? As in, other than initial starting climates, why would climate range even matter??? My climate is between 0F and 100F like 99% of the time. Every viscosity would pretty much work regardless.
That's ambient temperature, which is basically relevant for the initial starting "cold" engine temperature and ergo oil temperature. So like you said, really only the initial starting matters if you live at an extreme of the ranges like Alaska or Death Valley. Like you, I'm covered by all of those viscosities and 5W30 serves me fine for my West Michigan climate.
Old Apr 8, 2022 | 05:16 PM
  #42
CurtJ's Avatar
Originally Posted by RichardS
For climates ranging from -35°C to +50°C (-31°F to +122°F), the following oil viscosities may be used:
0W-30 protects from -35°C to +35°C (-31°F to +95°F).
5W-30 protects from -30°C to +35°C (-22°F to +95°F).
0W-40 protects from -35°C to +50°C (-31°F to +122°F).
5W-40 protects from -30°C to +50°C (-22°F to +122°F).
When it is -35°C, the convertible is staying in the garage and I'm staying by the fire. Don't really care about the oil viscosity at that point.
Old Apr 9, 2022 | 04:11 AM
  #43
Barry Leftwich's Avatar
Originally Posted by BabydriverX
Should oil change only be done by dealer? Acquired a 2007 XK convertible last year. It will be ready for an oil change in a few months. Would it be OK to go to an oil change place and have them put in Mobil 1 or fully synthetic Castrol, or do I really need to go to the dealer for special Jaguar oil? Thanks
This is the LAST THING that you should be worried about to get changed by a dealer when it comes to changing the oil on a 2007 unless this your very 1st car and think just because of the brand and how expensive this car was when it 1st came out,you thinking it's difficult and should be handled by professionals at the dealership or else this is a very pointless question that makes me sort of cringe reading this if you have had experience with other cars before.To really answer your question,I use to get WAL-MART to do oil changes on my 2007 XKR back when i had 1.Also the 3rd generation Jags are easier to do an oil change on than most cars of the same year from earlier decades.But the fluid changes you should be worrying about like the rest of us, is what shops can change the tranny fluids,differential fluids,and supercharger fluids??????Those are the serious main questions that every Jaguar owner needs answers to right there
Old Apr 9, 2022 | 07:59 PM
  #44
Gator8's Avatar
I changed the oil in my 2011 XK convertible today, using a kit that included 8 liters of Ravenol 5w20 and a Mahle filter. I have a vacuum extractor and the special wrench for the oil filter housing, and the whole thing took about 15 minutes. I only had to try seven or eight times to reset the service indicator. So far, the Earth seems to be continuing to rotate as usual. 😏
NavyBlue
Apr 6, 2022 07:59 PM
RichmondXK
Mar 21, 2013 07:27 PM
2002XK8Orlando
Sep 9, 2010 10:04 AM
moose
Jul 15, 2010 11:06 PM
wolffgod
Jun 8, 2008 10:05 AM
